QUESTION
Old Jan 28, 2009 | 02:48 PM
9000revolutions's Avatar
Thumbs up QUESTION
Was to lazy to dig the S out of snow and look for myself, But can someone help me out?
1 Do the exhaust flanges bolt together with studs and nuts or bolts and nuts?
2 What size hardware is used?
3 Does aftermarket exhaust hardware differ from OEM?
Old Jan 28, 2009 | 03:07 PM
TheDarkKnight's Avatar
Never had hardware. But mine i'm sure along with others hangs by the hangers. Hope that helps.
Old Jan 28, 2009 | 03:18 PM
Hardware = nuts and bolts
Old Jan 28, 2009 | 03:30 PM
magikcow's Avatar
pretty positive that they are studs and bolts for the oem cat.
Also the hardware is interchangeable. unless you're getting a test pipe too. Then you're going to need longer ones i think.
Old Jan 28, 2009 | 03:39 PM
ok nuts and bolts. I used the parts that came with my exhaust. What is your status are you getting an aftermarket one or going back to stock?
Old Jan 28, 2009 | 04:32 PM
skyl80's Avatar
Uhm... I have no idea but I've installed catless and catback exhausts.
There are two bolts with springs with nuts connecting the header to the cat.
There are three bolts that bolt the cat to the rear section by themselves.
As for the hangers... you just use the old hangers.
What are you doing exactly?
Old Jan 28, 2009 | 04:33 PM
magikcow's Avatar
he's removing his exhaust to give to oturn on sat.
WhrDLMI's Avatar
[quote name='9000revolutions' date='Jan 28 2009, 06:48 PM']Was to lazy to dig the S out of snow and look for myself, But can someone help me out?
Old Jan 28, 2009 | 04:35 PM
WhrDLMI's Avatar
I forgot about the springs on the bolts between the cat and the header... I bet those can be pulled out once you loosen them. I cannot speak from experience here, however, as I have never removed my cat.
Old Jan 28, 2009 | 04:46 PM
skyl80's Avatar
Originally Posted by WhrDLMI' date='Jan 28 2009, 08:33 PM
Damn, he brought out the super schematic.
