When Changing Your Engine Coolant
Old Jul 15, 2004 | 02:37 PM
FF2Skip's Avatar
Default When Changing Your Engine Coolant
FYI.
I changed my coolant today before heading out to Texas. I used my Honda service manual to guide me through the steps. I couldn't get the drain bolt out from the right side of the block. I even tried an impact wrench to no avail. Finally I phoned a friend. Turns out that they don't remove that bolt either. Just drain the radiator(no need to remove any plastic undertray) and fill as directed to in the manual. Drain the overflow resevoir also.
The manual calls for this service to be done at 45,000 miles. I did it as a preventative measure a little early.
Old Jul 15, 2004 | 04:31 PM
gfacter's Avatar
From what I have read here, no one bothers with the plug, now did you flush it really good?
I will be draining my coolant and changing my thermostat (Mugen) this weekend
George
Old Jul 15, 2004 | 04:34 PM
white_S2000@16's Avatar
haha have fun with that george when i put mine on it was a huge PITA make sure you align it properly other wise youl ruin the rubeer gasget not that i know or anything. i however did remove the plug and i flushed it i think 3 times with bottled water
Old Jul 16, 2004 | 05:00 AM
gfacter's Avatar
Thanks for the notice Matt, It looks like a PITA.
Old Jul 16, 2004 | 04:46 PM
Matt_in_VA's Avatar
Community Influencer
Thanks for the post Skip. I have toyed with purchasing a Service Manual, but now you make me wonder if it is money well spent? If it prompts one to do stuff that is incorrect?
For what it is worth last Monday I changed the MTF and did a slight overfill (As per XViper's thread about 1.8 Qts) and interestingly enough the "howl" that others have complained about all but went away! (?)
I think that it is interesting that there are claims that dealers charge as much as $145 for this "glorified oil change" for less than $9 worth of lube.
BTW I also changed my cabin filter (following Airgate's post) and at 29,865 miles I was amazed to see how dirty it was!
Old Jul 16, 2004 | 07:14 PM
the service manual isnt incorrect it is just kind of an uneescory step that skip is talking about
madenot
Jan 15, 2011 04:59 AM
S2000Matt
Aug 26, 2010 12:25 PM
S2K_2003
Jun 14, 2009 06:12 PM
TrackStar
Jan 10, 2007 06:03 PM
Prolene
Dec 11, 2001 09:19 AM
