Middle East S2000 Owners S2000 Owners from the Middle East and Gulf. Covers: UAE, Saudi, Quatar, Oman, Kuwait, Bharain.
obd2 diagnostics
Old Oct 25, 2006 | 10:16 PM
Ed S2K's Avatar
Default obd2 diagnostics
Do any s2k owners in dubai have an obd2 cable and the software for laptop to pull engine codes from the ecu.
Does anyone know where I can buy such a thing in the UAE?
Old Oct 25, 2006 | 10:40 PM
DesertRat's Avatar
Hi,
You can diy this for free if you have the skills/nerve. Thanks to Modifry and the 'Search' function...
What is the problem with your car?
Old Oct 26, 2006 | 12:25 AM
Ed S2K's Avatar
I tried this mod with grounding pin one and It didn't work, so I think that the engine code was not one that is valid DTC that can be read with this method, as im pretty sure I didn't do the mod wrong.
I thought the problem with the car was a map sensor problem. However I have noticed that the v-tec kick in is not as noticeable as it was.
Do you know of any garages that could pull the code for me from the obd2.
Old Oct 26, 2006 | 12:30 AM
DesertRat's Avatar
Trading Enterprises?
Old Oct 26, 2006 | 12:35 AM
DesertRat's Avatar
Do you have a CEL on?
The 'feel' of vtec kick in can be affected by many things. Humidity, temperature, dirty sparkplugs, low oil level, dirty air filter...
Can you tell if vtec does engage or not? In my car the sound changes (increases) quite noticeably when going to the bigger cam.
Old Oct 26, 2006 | 12:56 AM
Ed S2K's Avatar
The vtec does kick in just not as brutal as it used to be.
Have you tried the mod to get the engine warning light to do blink codes. I was wondering if the pin wiring is different in our cars to the american ones.
The oil level is fine and filter is clean..
Cheers
Old Oct 26, 2006 | 02:58 AM
DesertRat's Avatar
No I have not tried that mod. Can't try it now, or if I would I would get the DTC for "No Engine"
Old Oct 26, 2006 | 03:55 AM
umair_k's Avatar
Think only TE can do this. wont trust anyone else with this. You can CHECK with subzero if they can help.
Old Oct 26, 2006 | 08:06 AM
Ed S2K's Avatar
Thanks for the info.
I have bought a full diagnostics system from the states ($150), which has cable and full software for laptop. So that should be here in a couple of weeks. Its a good tool to have anyway to see how the ecu reacts after modifications and that sort of thing. This software also measures 1/4 mile times and speeds as well which is quite handy for comparisons after modifications.
Ill let you know when I get it if any one is interested in having a look.
Old Dec 5, 2006 | 03:23 AM
umair_k's Avatar
But would you be able to tune the car with the same software? I dont think you can write on the factory ROM.
I will surely be interested in looking at it. I know of a friend who does ROM writing using a software and changes the chip on B series engines.
trackrabbit21
Aug 10, 2022 04:44 PM
atomicrm
Mar 27, 2013 01:29 PM
toniotran
May 18, 2010 07:24 AM
s2kmovement
Jun 20, 2007 10:24 PM
jackalope
Jan 28, 2007 04:42 PM
