Air filter
Old Mar 30, 2010 | 04:09 AM
ajlafleche's Avatar
Default Air filter
Just what the headline says.
I have to replace my air filter. Is the basic K & N filter worth the extra price? If not, any suggestions for a good replacement?
Thanks for your input in advance.
Old Mar 30, 2010 | 05:09 AM
HARDtoTOP's Avatar
IMO, no it's not worth it. If you have the OEM box, I prefer the OEM filter. The amount of flow gained through the K&N is negligible at best and I doubt it even makes a difference.
Pros: Cost more so it must be better (kidding). Comes with a K&N sticker. Some folks can put it in their sig line as a mod. Box says adds HP (yeah right).
Cons:
It doesn't make any better sound. It doesn't look any better because it's covered. You have to waste time cleaning it and then oiling it and letting it dry.
Old Mar 31, 2010 | 09:49 AM
ajlafleche's Avatar
Thanks, Jeff.
Old Mar 31, 2010 | 10:14 AM
LazyProfessor's Avatar
I had the opportunity to have the car on the dyno when i changed to a KN filter. I did see an average of 5hp over 3 runs. I have a OEM air box.
Averaged 1.5 hp inc for changing to Royal Purple oil too
Old Mar 31, 2010 | 11:08 AM
PsychoBen's Avatar
Gain probably came from a new, clean filter more than anything else. If you plan on keeping the car for a while, K&N-like filter is worth it since it is reusable whereas the OEM is not.
Old Mar 31, 2010 | 11:19 AM
drhess06259's Avatar
K and N is better in the long run as it is cleanable the oem has to be replaced. other then that not much of a difference. imo.
Old Mar 31, 2010 | 12:09 PM
FitzyS2k's Avatar
I would deff use some air intake cleaner after driving around with the K&N fliter cause it lets more stuff into the engine esp. if you have a snorkel like i do. i clean my engine every spring because you inhale alot of winter driving crap into the engine.
Old Mar 31, 2010 | 02:18 PM
mosesbotbol's Avatar
I had one. It was no different than OEM, but at least I could clean it. You'll have to do the math over your ownership to see if it's worth it. You won't notice a difference really.
Old Mar 31, 2010 | 03:10 PM
HARDtoTOP's Avatar
I gotta wonder if it's really cheaper when you consider the cost of having to buy the cleaning kit too. You can buy a few OEM filters for what it cost you to set up with K&N. I guess if you plan on having the car for 20 years it will definitely save a few dollars. Then again, time is money too.
Old Mar 31, 2010 | 04:46 PM
zzziippyyy's Avatar
KN reusuable
OEM not
you do the math
