changing the oil article
Old Mar 25, 2009 | 09:41 AM
jtpassat's Avatar
Default changing the oil article
pretty good article about changing oil
http://www.blackstone-labs.com/newsletter....tm_medium=email
Old Mar 25, 2009 | 10:02 AM
CTMechE's Avatar
It's interesting, but unless I start doing oil analysis, it still doesn't help me. So do I spend money changing my oil more often, or doing analysis?
Old Mar 25, 2009 | 10:37 AM
The Hoth's Avatar
I do it once a year. Not sure I should do it right before or after hibernation.
Old Mar 25, 2009 | 10:41 AM
zzziippyyy's Avatar
^ I do both before and after Last year i put in 2700 miles talk about overkill eh
Old Mar 25, 2009 | 11:43 AM
jtpassat's Avatar
do the oil analysis because it can tell you if you are actually having engine related issues such as excessive wear and oil contamination by fuel or anti-freeze, etc
not to mention reducing unecessary oil changes is being environmently friendly.
Old Mar 25, 2009 | 12:31 PM
boltonblue's Avatar
Dave,
what do you think is happening to the oil in your engine as it sits over the winter?
that would be different from, say for example, sitting in a plastic bottle on the shelf?
how many seconds of run time does it get between the fall oil change and the spring oil change?
Old Mar 25, 2009 | 12:42 PM
NH_s2k_Guy's Avatar
I do it before it goes into hibernation. Gives the motor a chance to run
the clean oil through the engine and pick up any impurities so when the
oil drains down to the pan, you don't have that gunk sitting on your
engine all winter.
I run Mobil 1 for 7500 miles between changes. I'm figuring there is still
plenty of life left in it when I change it even at that interval. Please
correct me if I'm wrong.
Old Mar 25, 2009 | 12:48 PM
daktruckie99's Avatar
After 6700 miles on my M1 10w30 my numbers were quite scary. I'll post up the report later.
I've moved to AMSOIL.
Old Mar 25, 2009 | 12:52 PM
gladwins's Avatar
Same here. I run synthetic every season, usually 3000 - 3500 miles worth and change to the fresh stuff before she sleeps. It's probably overkill, but I like to start her after 4 months with no worries of grit and grime in the oil.
Jerry, is there a chance the oil could gel over those months as well? Not that my garage gets below freezing but still... The bottle on the shelves see room temperature until they are bought.
Old Mar 25, 2009 | 01:08 PM
boltonblue's Avatar
scott,
do you think trucks and warehouses are always heated? sorry but the answer is definitely no.
Conceptually if you had different fractionations you could get some marginal separation due to temp.
But a Mobil 1 is just homogenic and remarkable consistent.
Freezing the oil is not going to modify it's chemical composition unless you got it really, really cold and I still wouldn't bet on any changes.
It takes energy in the form of heat, and a lot of it, to break the bonds and denature the oil.
so assuming you change it in the fall ( good time, I agree), doing it a second time in the spring doesn't have a demonstrable benefit that I am aware of.
