how do i fix this?
Old Jun 6, 2009 | 08:32 PM
kenta's Avatar
Duct tape.
Old Jun 6, 2009 | 09:56 PM
m1sterlaw's Avatar
super glue
Old Jun 8, 2009 | 10:19 AM
stock04's Avatar
Hammer the hell out of it until it fits back in the hole. And you can use something else in there to make up for the missing piece.
Old Jun 8, 2009 | 12:04 PM
scho01's Avatar
can you hack saw off enough of the bad end so it slides in?? Then hack off the other side to match, so the canopy's a little lower?? Without an overall pic, I'm guessing.
Old Jun 8, 2009 | 12:08 PM
Bass's Avatar
maybe
here's what it looks like attached
Old Jun 8, 2009 | 12:11 PM
stock04's Avatar
cut both sides, and it'll look good as new
Old Jun 8, 2009 | 12:12 PM
The Hoth's Avatar
Mighty puddy!
Old Jun 8, 2009 | 12:14 PM
Bass's Avatar
it's the top corner of the rear of the canopy
mighty putty
Old Jun 8, 2009 | 07:07 PM
RedY2KS2k's Avatar
Bass,
If you can find tubing to sleeve the damaged area, either inside or outside, I'd recommend that you buy an oxy-MAPP torch kit. They're about $50 at Sears, Lowe's, etc. They use the standard MAPP cylinder and an oxygen cylinder that is the same size. They won't weld, but they will braze. Bronze brazing rod with a sleeve will save your butt when the work needs to be done and replacement parts are a week away. I use mine about once every 5 years, and it's worth its weight in gold.
Old Jun 9, 2009 | 01:56 AM
Bass's Avatar
Thanks for all the tips
