Key Programming
Old Mar 14, 2012 | 07:35 PM
Vinny_GPW-S2K's Avatar
Default Key Programming
I know home depot and ace hardware does but you need to purchase there key and not use the one you bring to them.
Old Mar 14, 2012 | 07:40 PM
Have any one try this method and programming there own keys?
STEPS:
1. Begin by sitting in the driver seat with all the doors shut.
2. Insert your working master (black) key in the ignition.
3. Very Quickly, turn the key from "LOCK" to "ON" 5 times. (You will end with the key in the "LOCK" position)
4. Immediately, open and close the driver door 6 times very quickly. (End with the door closed)
5. Immediately, remove your working Master Key and insert your new Master Key
6. Turn the key to the "ON" position and leave it there while you wait for 1 minute.
7. After the minute, if you want to program another key, just remove the first one and insert the next one, turning it to "ON" and leaving it in position for 1 minute.
8. When you are through programming keys, just take the last one out, open and then close the driver door to lock in the programming, and your done
Old Sep 8, 2013 | 04:56 AM
TTMartin's Avatar
STEPS:
Did this work?
Old Sep 8, 2013 | 05:24 AM
blade954's Avatar
Originally Posted by TTMartin
STEPS:
Did this work?
I have the same question.
I've just got the feeling that all I will achieve by doing this is having people laughing at me for flapping my door like a birds wing!!!
but if someone has a quiet place where they can try this and confirm it, I'm willing to try. After assigning a new master key, will I need to reinsert the old one, or will it remember it?
Old Sep 9, 2013 | 05:29 PM
xxmass's Avatar
in mass, at the woburn mall, i purchased theirs, they cut/copied and programmed using my current original key for less than $50. perhaps you could call them and ask about using your own cut key.
Old Sep 12, 2013 | 06:06 AM
AZfury's Avatar
if anyone needs keys programmed, let me know, im at a dealer, will give a great deal
fivlemon
Feb 2, 2015 04:51 PM
deanbayley
May 1, 2012 08:46 AM
GoldLude
Nov 2, 2011 02:31 PM
ED1
Dec 23, 2005 02:35 PM
dlq04
Sep 13, 2002 04:30 PM
