Kingz needs a hand.
I get a call from Kingz (Luis). He is on the way back from NY when his S starts to bog really bad. Pulls off the highway and the car stalls. He is able to start it and it will run at idle with a CEL at about 1000 RPM. Shortly thereafter the idle will drop to 300ish. If he touches the throttle it will stall.
I'll be relaying any suggestions.
Thoughts??
Thoughts??
Originally Posted by zzziippyyy,Jul 2 2008, 01:27 PM
sounds like heatsoak, but in an extreme way quick things to try open hood let it cool some, turn off the ac if its running and reset ecu by unhooking battery.
Originally Posted by LazyProfessor,Jul 2 2008, 01:31 PM
is there an ecu fuse??
the ecu fuse is the same as the radio fuse - think it's a 7.5 under the dash
