lude problems?
Old Jan 8, 2007 | 06:35 AM
Bass's Avatar
CHECK - won't disconnect the battery while car is running!!
wd-40 around the alt BUT not the belts
Bill - maybe i can swing by tonight just to pick up the helms to see if there's a blown fuse or something because the speedo doesn't work either
plan to take Friday off if this doesn't fix itself
Old Jan 8, 2007 | 06:38 AM
Legal Bill's Avatar
I should be home all night working in the garage. Swing by anytime after 7:30
Bass's Avatar
Thanks Bill!!
Old Jan 8, 2007 | 07:13 AM
specialque's Avatar
Steve, which board do you use?
This happened when I cleaned my engine bay with the powerwasher. The connections that go into the firewall are not sealed correctly and often cause shorts to the interior lighting. The prelude tail lights and brake lights are also on the same relay as the interior lights, namely the gauge pod. This is done so if you have an electrical issue or you blow a fuse for your taillights you'll know right away. I would check the connections from the fusebox to the harness that goes into the firewall. I dried mine up and it was the cause of the problem.
Hope this helps
Old Jan 8, 2007 | 07:17 AM
TheToon's Avatar
Steve, sorry to hear of your troubles with this. I wish I could be of some help, but the only Lude issues I've ever had was passing out from taking too many.
Old Jan 8, 2007 | 07:34 AM
Bass's Avatar
Hope this helps
awesome Thanks Luke!!
been using prelude power
Old Jan 8, 2007 | 07:42 AM
specialque's Avatar
Give up on preludepower it's a waste of time.
Either pay the $6 for preludeonline.com or use Absoluteprelude. Anyone that knows anything about the car including myself are on those two boards, that's it.
Luke
Old Jan 8, 2007 | 07:43 AM
Bass's Avatar
check!!! will send the $6.00 to preludeonline.com
Old Jan 8, 2007 | 07:49 AM
Cubs2k's Avatar
Hit that harness the Luke was talking about with the WD40.
Old Jan 8, 2007 | 08:57 AM
Bass's Avatar
done
this is getting weird - got on the car to see of vtec will kick in and the speedo jumped up and down and then the abs light came on
more reseach needed
