wd-40
wd-40
heres a little tidbit of info on WD-40 I thought you guys would like to read .
WD-40
I thought that you might like to know more about this well-known WD-40 product.
When you read the "shower door" part, try it. It's the first thing that has cleaned that spotty shower door. If yours is plastic, it works just as well as glass. It's a miracle!
Then try it on your stovetop... Viola! It's now shinier than it's ever been. You'll be amazed.
The product began from a search for a rust preventative solvent and degreaser to protect missile parts. WD-40 was created in 1953 by three technicians at the San Diego Rocket Chemical Company. Its name comes from the project that was to find a " W ater Displacement" compound.
They were successful with the Fortieth formulation, thus WD-40.
The Corvair Company bought it in bulk to protect their Atlas missile parts.
The workers were so pleased with the product they began smuggling (also known as "shrinkage" or "stealing") it out to use at home.
The executives decided there might be a consumer market for it and put it in aerosol cans. The rest is history. It is a carefully guarded recipe known only to four people. One of them is the "brew master." There are about 2.5 million gallons of the stuff manufactured each year. It gets its distinctive smell from a fragrance that is added to the brew. Ken East (one of the original founders) says there is nothing in WD-40 that would hurt you.
Here are a few of the 1000s of uses:
~Protects silver from tarnishing
~Cleans and lubricates guitar strings
~Gets oil spots off concrete driveways
~Gives floors that 'just-waxed' sheen without making it slippery
~Keeps flies off cows
~Restores and cleans chalkboards
~Removes lipstick stains
~Loosens stubborn zippers
~Untangles jewelry chains
~Removes stains from stainless steel sinks
~Removes dirt and grime from the barbecue grill
~Keeps ceramic/terra cotta garden pots from oxidizing
~Removes tomato stains from clothing
~Keeps glass shower doors free of water spots
~Camouflages scratches in ceramic and marble floors
~Keeps scissors working smoothly
~Lubricates noisy door hinges on vehicles and doors in homes
~Gives a children's play gym slide a shine for a super fast slide
~Lubricates gear shift and mower - deck lever for ease of handling on riding mowers
~Rids rocking chairs and swings of squeaky noises
~Lubricates tracks in sticking home windows and makes them easier to open
~Spraying an umbrella stem makes it easier to open and close
~Restores and cleans padded leather dashboards and vinyl bumpers
~Restores and cleans roof racks on vehicles
~Lubricates and stops squeaks in electric fans
~Lubricates wheel sprockets on tricycles, wagons and bicycles for easy handling
~Lubricates fan belts on washers and dryers and keeps them running smoothly
~Keeps rust from forming on saws and saw blades, and other tools
~Removes splattered grease on stove
~Keeps bathroom mirror from fogging
~Lubricates prosthetic limbs
~Keeps pigeons off the balcony (they hate the smell)
~Removes all traces of duct tape
~I have even heard of folks spraying it on their arms, hands, and knees to relieve arthritis pain. ~Florida's favorite use was "cleans and removes love bugs from grills and bumpers
~The favorite use in the state of New York
~ WD-40 protects the Statue of Liberty from the elements.
~WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will be catching the big one in no time. It's a lot cheaper than the chemical attractants that are made for just that purpose. Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
~Keeps away chiggers on the kids
~Use it for fire ant bites. It takes the sting away immediately, and stops the itch.
~WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
~Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and re-wash. Presto! Lipstick is gone!
~If you sprayed WD-40 on the distributor cap, it would displace the moisture and allow the car to start. (If I knew what a distributor cap was, it might help)
~WD-40, long known for its ability to remove leftover tape smudges (sticky label tape), is also a lovely perfume and air freshener! Sprayed liberally on every hinge in the house, it leaves that distinctive clean fresh scent for up to two days!
~Seriously though, it removes black scuff marks from the kitchen floor! Use WD-40 for those nasty tar and scuff marks on flooring. It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off. Just remember to open some windows if you have a lot of marks.
~Bug guts will eat away the finish on your car if not removed quickly! Use WD-40!
My personal favorite is freeing frozen locks in the winter, but you need to use the tube supplied to direct the stream.
This is what you use to take adhesive off ,Not PB Blaster , Blaster products do make a auto polish and adhesive remover in their line up . PB will eat a Styrofoam cup and contains silicon . If you do use it on your paint make sure to clean it off well with soap and water then apply wax ASAP to keep the paint fresh .
WD-40
Originally Posted by Twiztid,May 27 2006, 10:00 AM
This is what you use to take adhesive off ,Not PB Blaster , Blaster products do make a auto polish and adhesive remover in their line up . PB will eat a Styrofoam cup and contains silicon .....
Originally Posted by Twiztid,May 27 2006, 06:55 AM
Originally Posted by honda_s2k,May 27 2006, 04:37 PM
Be careful if you spray it into a stubborn small engine like a lawn mower, etc.. The propane in the can ignites instantly.
I almost lost a few eyebrows!
FluKy15
12-23-2014 06:28 AM
