need help!
Let me know once you have it installed, I'll show you how to turn it on!
What kind is it? Jerry's right there's tons of info in the electronics forum. In fact if you just post your question someone is bound to offer some advice! Are you going to be able to still use your dash controls?
Originally Posted by 505sduece,Oct 31 2006, 09:32 AM
i dont know what the **** am doing i need some help
Just had to harrass you!
So whats the problem? That Modifry kit has connectors that plug right into your stock wiring harness. Theres an IR cable, that looks like a stereo headphone jack, on the Modifry that plugs into the back of your deck. You still have to crimp or solder some wires to get it all to work. Theres also a speedo wire that has to run over to the compartment above the passenger footwell.
Like JanNov and Rick said, check out the DIY forums. There's pictures and everything.
Good Luck!
