New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
Pcv valve problem
Old 05-20-2010, 06:43 PM
Armend17's Avatar
Default Pcv valve problem
Okay here's the story people were telling me that if i change the pcv valve it will help the oil consumption, so i go and i buy one from autozone, i install it and everything is fine the second day i check it and it's loose like it doesn't click in so i guess i lost the ring around it, i have no idea how but my question is how can i pick one up, online or dealer? is there a name for it?
Old 05-21-2010, 06:38 AM
orangebarius's Avatar
i would buy an oem pcv valve from the dealer. ive used ones from auto parts store and they just dont fit like a honda one.
Old 05-21-2010, 07:04 AM
maluch's Avatar
it doesnt fit because the rubber on the valve cover is missing....you must have pulled it out with the old pcv valve. if this is the case buying a new pcv valve wont help.
in the stock setup there is a rubber gasket on that pcv valve hole on the valve cover. you then must push the pcv valve into the rubber gasket...
you can see the print of the rubber gasket on the lower picture. it looks like a ring around the pcv valve
Old 05-21-2010, 07:31 AM
^ he is 100% correct.
Old 05-21-2010, 08:05 AM
quickshifting's Avatar
off topic but, i dont ever remember having a zip tie on the hose.
did you put that there?
Old 05-21-2010, 08:19 AM
maluch's Avatar
its not stock, he put the zip tie in... you should see my engine bay. since i swapped my motor there are zip ties all over.. i sometimes fear that if one of them breaks i might loose an engine on the way
Old 05-21-2010, 02:21 PM
Armend17's Avatar
Yeah, i put it there till i get the ring for it, i still have no idea how i lost it.
Old 05-22-2010, 07:02 AM
Billman250's Avatar
Received 1,306 Likes on 794 Posts
I got a few laying around, you're welcomed to one.
Its called a PCV valve grommet.
Old 05-22-2010, 10:31 AM
Armend17's Avatar
Thank You Bill, i ordered one online should be here soon.
codyh
07-23-2012 03:41 AM
s2konroids
01-26-2011 01:18 PM
cthree
S2000 Service Bulletins (TSB)
03-12-2005 09:57 AM
tboy911
05-23-2003 09:31 AM
Quick Reply: Pcv valve problem
