New York - Upstate New York S2000 Owners All areas North of I-84 (Port Jervis to Putnam Lake) in New York State
Speaking of old men, How do I get to the upper clutch pedal switch? Jake ???
Old 04-12-2017, 05:32 AM
freq's Avatar
Originally Posted by Bugsy
Switch is fine.
I just want to feed a scotchlock between the wires to bypass the switch.
Id do it right now if I could get to it.
I'm thinking of grounding the light blue interlock relay wire, but didn't want to pull that fuse block.
I just made a hard loop out of some solid 18(?) gauge wire and zip-tied it onto the connector.
Easy to undo should the need arise and less intrusive than a scothlok IMHO.
Old 04-24-2017, 12:33 PM
minh's Avatar
having the same issue, i don't have a large hand and still having trouble getting my hand in a position to be able to unplug the clutch interlock switch
Old 04-24-2017, 04:44 PM
Bugsy's Avatar
It's almost impossible.
Ive given up for now...
Old 04-28-2017, 04:30 AM
jsenclosure's Avatar
I just replaced every wiring harness in the car, and if i can get in there and do that it's for sure possible. I can do it for you next time i see you, a skinny waist and long arms help. save it for mod day
Old 04-28-2017, 04:32 AM
what s the point of this, just to be able to start the car without the clutch pressed down?
Old 04-28-2017, 05:05 AM
Chuck S's Avatar
Received 1,134 Likes on 997 Posts
It's a tight squeeze under there for sure but I don't understand why anyone would want to bypass the clutch interlock switch either. A solution to what problem?
-- Chuck
Old 04-28-2017, 02:56 PM
pgss2k's Avatar
Perhaps he is trying to test /start the car in the garage and doesn't want to have to crawl in and out every time.
As someone getting older I can sympathize if that's it
Old 04-28-2017, 07:00 PM
Bugsy's Avatar
Most other markets don't have the switch, but us dumb Americans with a lawyers on retainer smell lawsuits. I know how to start a car. I don't need TPMS and some other nannies either. I liken this to the top down mod.
The purpose of this is thrust surface longevity. Most wear happens at cold start, and if the crank isn't loaded at startup, it only makes sense that the thrust face which is only a small half moon surface may live a lot longer.
The engine is smoked if the crank walks. Granted, many, many folks will have no issue ever. I choose to start in neutral, or if I want to, also start with clutch in.
Old 04-28-2017, 07:04 PM
Bugsy's Avatar
...Oh, and Jake, thank you for offering up your help at next mod day. This old bod of mine is R-19 in a tee shirt and just doesn't bend like it used to. I think I'd be a strange extrusion like what would come out of play dough fun factory if I squeezed in there. You're a hero dude...
Old 04-28-2017, 07:22 PM
minh's Avatar
i finally got it!
so instead of unplugging the switch, i managed to pull the wire down just enough to tap into them using these posi 20-22 gauge taps...i don't know how the other guys are able to strip and solder these wires in such a small space!
mswitz88
08-17-2015 09:23 AM
mikey_w50
06-05-2015 12:32 AM
DonJ
19
01-05-2010 06:52 PM
mikecorpen
08-03-2005 12:05 PM
michaelg
04-27-2003 06:50 AM
Quick Reply: Speaking of old men, How do I get to the upper clutch pedal switch? Jake ???
