adobe design software
Old Jan 9, 2005 | 06:26 PM
emrillive's Avatar
Default adobe design software
I have a logo on illustrator and need to transfer it or reopen it onto indesign. does anyone know how i should save it so that i can open it up using indesign?
cause the only way i see it, is to control copy it or drag it across to indesign and that causes the color and the logo to go dull.
i did it before but havent used it for so long that i forgot.
thanks
Old Jan 9, 2005 | 07:40 PM
amongmany's Avatar
You can copy and paste it, but it sounds like you're working in two different color gammuts. Maybe one is in RGB and the other is in CMYK?
Try saving the illustrator file as a .EPS file and then importing that into indesign. If that doesn't work, you can open it in photoshop and save it as whatever you need to.
Old Jan 11, 2005 | 06:02 AM
Dark_Sub_Rosa's Avatar
.eps files work in Quark so I'm assuming Indesign would be the same. worse case scenerio use Photoshop and make it a .tif
Be sure the file is set up for 300 dpi CMYK or your gonna have a headache printing it
Red Blur
Sep 23, 2003 07:24 PM
Ludatic
Aug 25, 2002 08:26 PM
