Chemisty 101 Help
Old Sep 5, 2009 | 12:53 AM
krnmike's Avatar
u still there?
Old Sep 5, 2009 | 12:57 AM
JDM_JOE's Avatar
Originally Posted by krnmike,Sep 5 2009, 12:38 AM
Basically, it's the same trick over and over.
Here are some good tips:
1. the exponents like 10^2 10^3 or whatever, should be treated as minorities (keep them for last). keep them segregated for now.
2. DO THIS FIRST: multiply and/or divide the weird numbers like 7.1 3.6 7 or whatever number that is separate from "10^whatever"
So on question B would my answer be .32520 x10^2 in scientific notation? If not I will post my work to find out what I did wrong.
Old Sep 5, 2009 | 12:59 AM
krnmike's Avatar
Old Sep 5, 2009 | 01:02 AM
krnmike's Avatar
for B, you should've gotten a much bigger exponent than that.
the answer should be
3.25x10^11
scientific notation usually requires you to write the form like this:
#.## x 10^#
notice how on the left side of the decimal, there is only 1 digit.
Old Sep 5, 2009 | 01:04 AM
JDM_JOE's Avatar
On B I was confused on the positive and negative exponents. I subtracted them. So even if one is positive and the other is negative I add them as if they where the same?
Old Sep 5, 2009 | 01:07 AM
krnmike's Avatar
i'm writing you a guide on that right now. hold up
Old Sep 5, 2009 | 01:10 AM
krnmike's Avatar
Old Sep 5, 2009 | 01:15 AM
krnmike's Avatar
negative exponents can be sent up or down to undo its negative sign.
(10^-2) can be 1/(10^2)
1/(10^-2) can be (10^2)
1/(10^2) = no need to change since it's already positive and simple to solve
(10^2)(10^-4) = (10^2)/(10^4)
yea it's that simple, just move it up or down to get rid of the negative sign. it just makes things easier before you start really solving it.
Old Sep 5, 2009 | 01:16 AM
krnmike's Avatar
since this is a division of exponents, you subtract the critical number "2" and "4"
like this:
10^(2-4) = 10^-2
again, you can write that as 1/(10^2) just for the hell of getting rid of the negative sign.
Old Sep 5, 2009 | 01:20 AM
JDM_JOE's Avatar
Ok I am gonna mess around with your guide and see if I can perfect this. You made more sense in 30 minutes then my teacher did in 4 hours lol.
