Having problems formatting PC
Old May 28, 2004 | 09:31 AM
LostWaffle's Avatar
Default Having problems formatting PC
I need to format to make sure I kill all those bloody viruses and spyware. I'm running XP. i go to command prompt and type "formate c:" and then hit "y" for yes.
But then it says I can;t do it because something "is still using the load"
Load of what?
How do I get around this problem?
Old May 28, 2004 | 09:43 AM
WhiteS2k's Avatar
You really need to boot off of a separate media in order to reformat your hard-drive. For example, if you have a "recovery floppy", you can boot off of that and then reformat your hard disk. Or you can boot off of a Win/XP installation CD and reformat your hard disk as part of the installation process. If nothing else, get yourself a DOS, Win/95, or Win/98 boot floppy and just do "fdisk" to delete all the disk partitions on the hard disk. Then when you install Win/XP again, it will detect that your hard disk is not partitioned and format it for you. Good luck.
Old May 28, 2004 | 10:32 AM
LostWaffle's Avatar
Thank you!
Old May 28, 2004 | 11:47 AM
nigashorty's Avatar
yea...you can try bootdisk.com ...if you have XP pro/home just download the setup disks...its 6 floppies if you are going with this process...
Old May 28, 2004 | 12:44 PM
Elistan's Avatar
I believe the XP CD-ROM itself is bootable also. You can do a fresh OS install and tell it to reformat in the process.
Old May 28, 2004 | 01:17 PM
WhiteS2k's Avatar
Forgot to add: If you go the "fdisk" route, don't forget to do "fdisk /mbr" to re-install the Master Boot Record, just in case a boot-sector virus is hiding there.
Old May 28, 2004 | 01:29 PM
mondo3's Avatar
Save your important files first!
Old May 28, 2004 | 04:53 PM
Quik S2K's Avatar
I agree. Why not run a recovery and a virus scanner?
Old May 28, 2004 | 09:12 PM
TepEvan's Avatar
why not just ship the pc to me and I'll charge you about $50 an hour to look at/fix it
Sunny_P
Mar 12, 2001 10:15 AM
