Impact Wrench....
Old Nov 8, 2004 | 02:39 PM
NFRs2000NYC's Avatar
Default Impact Wrench....
Whats up guys.....I am a novice mechanic, that can do many "simpler things" on a car.....such as change a clutch, install supercharger, etc....not like changing a crank, installing diff. gears etc. So I am looking to purchase an ELECTRIC (not air) Impact wrench. I was looking at this one...
Click to check it out
This thing produced 240ft/lbs of Tq. Its decently priced at $179
My question is....what kind of Tq numbers are needed to work on my car.....(lugnuts, coilover towers, supercharger install <I know some of these need to be torqued to proper numbers> , subframe bolts, etc) Is 240ft/lbs enough, or do you need WAY more???
Also, if anyone can recommend other impact wrenches or a better deal somewhere, please dont hesitate to post. Thanks in advance.
Old Nov 8, 2004 | 02:53 PM
nivek2002's Avatar
Perfect! This should only be used to loosen bolts however. Anytime your installing and tightening always use a torque wrench! Good luck, working on your car is very rewarding!
Kevin
Old Nov 8, 2004 | 04:05 PM
mingster's Avatar
You may also want to look at cordless types that may be cheaper, and with higher torque ratings (18V)
Old Nov 8, 2004 | 05:15 PM
To add to this topic....can someone with an electro-engineering knowledge explain to me how can something running on a battery have MORE power than something that has a constant flow of juice?
Old Nov 8, 2004 | 08:58 PM
mingster's Avatar
motor rating, gear ratio, a multitude of possible reasons.
Old Nov 9, 2004 | 07:07 AM
TrojanHorse's Avatar
Kart racers use cordless ones all the time at the track. I use a Makita cordless all the time for my kart racing work. I only need up to about 80 ft-lbs but Makita makes larger models if needed. I have never had a problem with mine and I abuse the crap out of it, recommend them highly.
Old Nov 9, 2004 | 07:26 AM
r_duff's Avatar
Makita = JDM
Old Nov 9, 2004 | 07:39 AM
vader1's Avatar
My brother found this out after having a new set of tires put on his car by the local tire shop. When we tried to remove the wheels to swap brake pads, 4 wheel studs broke because the tire "technician" used an impact wrench to tighten the lugs and tightened the poop out of them.
Old Nov 9, 2004 | 09:14 AM
Solless's Avatar
he most likely cross threaded them
thats why if you use an impact to tighten lug nuts you have to use something like this:
http://www.torquestick.com/
Hand torquing is still preferred
Old Nov 9, 2004 | 08:01 PM
Voodoo_S2K's Avatar
The problem with cordless impact guns is that they only get their maximum torque with a fresh battery. With a corded or air impact gun, you always get maximum torque.
Revenge
Oct 22, 2009 12:07 PM
Tuan Le
Apr 7, 2005 04:11 PM
mas
Oct 25, 2002 08:49 AM
