Joke ---Oldie but Goodie
Old Jan 30, 2001 | 04:11 PM
Luder94's Avatar
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 and noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. No mention of this phenomenon was included in the product brochure. In addition, Wife 1.0 installs itself into all other programs and launches during system initialization, where it monitors all other system activities. Applications such as Pokernight 10.3, Boys Night 2.5, and Saturday Football 5.0 no longer run, crashing the system whenever selected. I cannot seem to keep Wife 1.0 in the background while attempting to run some of my other favorite applications. I am thinking about going back to Girlfriend 7.0, but un-install does not work on this program. Can you help me, please!!!
Thanks,
Joe
Dear Joe:
This is a very common problem men complain about but is mostly due to a primary misconception. Many people upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0 is merely a "UTILITIES & ENTERTAINMENT" program. Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run everything. It is unlikely you would be able to purge Wife 1.0 and still convert back to Girlfriend 7.0. Hidden operating files within your system would cause Girlfriend 7.0 to emulate Wife 1.0 so nothing is gained. It is impossible to un-install, delete, or purge the program Files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do this.
Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more problems than the original system. Look in your manual under "Warnings-Alimony/Child Support." I recommend you keep Wife 1.0 and just deal with the situation.
Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding General Partnership Faults (GPFs). You must assume all responsibility for faults and problems that might occur, regardless of their cause. The best course of action will be to enter the command C: APOLOGIZE. In any case avoid excessive use of the "Esc" key because ultimately you will have to give the APOLOGIZE command before the operating system will return to normal. The system will run smoothly as long as you take the blame for all the GPFs.
Wife 1.0 is a great program, but very high maintenance. Consider buying addition software to improve the performance of Wife 1.0. I recommend Flowers 2.1 and Chocolates 5.0. Do not, under any circumstances, install Secretary with Short Skirt 3.3. This is not a supported application for Wife 1.0 and is likely to cause irreversible damage to the operating system.
Best of luck,
Tech Support.
Old Jan 30, 2001 | 04:22 PM
huyto's Avatar
HAHAHAHAHAHHAHAHHAHA (tears) HAHAHHAH
Man, I think I have girlfriend program 7.0 who has downloaded Wife Program 1.0 from the net and installed without my knowledge. Now, I can't find anyway to uninstall because its affected the whole system and theres no way to just delete some of the files without deleting the whole girlfriend 7.0 program.
Old Jan 31, 2001 | 11:32 AM
lvs2k's Avatar
You might have to upgrade to GF 8.0, then rewrite the code to create wife 2.0. Then remember, Beta test, Beta test, Beta test!
Old Jan 31, 2001 | 11:49 AM
Pinky's Avatar
You can always install a hidden program Mistress 3.5. Though if not kept a hidden file Wife 1.0 will be infected ExWife 1.2 a hostile virus program which totally demolishes your OS.
The Raptor
Apr 17, 2006 12:08 PM
p0pe
Jan 29, 2005 06:14 AM
VFROOOM
Dec 26, 2004 08:34 PM
AquilaEagle
Mar 17, 2003 11:37 AM
