MS Access help?
Old Aug 1, 2005 | 04:14 PM
stockae92's Avatar
Default MS Access help?
I have a question regarding MS Access (which may or may not need an expert to answer )
When I specify in the startup manual (tool -> startup) to pretty much remove all menus, button, special keys, etc.
how can i bring them back [if i wish to]?
somebody told me to press the [Shift] key when starting the Access file up but it didn't work.
thanks
Old Aug 1, 2005 | 05:54 PM
DaveZ's Avatar
I'm no Access pro, but did you try start Access first, then open the file and go back to "tools --> startup" and re-enable the options?
Old Aug 1, 2005 | 07:54 PM
steven975's Avatar
yep. tools-startup. to get to the database window after you have disabled it, I think it is under click on "enable database window"
if you are talking about the file/edit menu and what-not, those are only disable-able through VBA scripting.
Once you get the database window up, you can right-click in that top window area to bring back all of the button groups. there is a button in one of the button groups for the database window. once you get that window open, right-click and select startup. the startup options appear.
Old Aug 1, 2005 | 11:14 PM
flitcroft's Avatar
FYI, PM excel2excel if you have more questions. That guy's a master to the point where it's his S2KI name...
flitcroft
Mar 30, 2005 08:56 AM
Austblue
Mar 29, 2004 08:27 AM
WestSideBilly
Aug 26, 2003 06:29 PM
mingster
Apr 11, 2001 09:26 PM
