Which one burns more calories on the trackmil?
Old Oct 24, 2008 | 11:44 AM
S2020's Avatar
Originally Posted by sahtt,Oct 24 2008, 11:34 AM
Depends on how fast you are running, the grade of the slope, and the speed on that grade. Usually running.
yup. The OP question does not, as they said in math problems, contain enough info.
Old Oct 24, 2008 | 07:34 PM
Orpheus's Avatar
Originally Posted by stockae92,Oct 24 2008, 12:37 PM
thanks guys
my question was more like speed vs grade?
if i run on the trackmil, with similar amount of time and effect, which one burns more calories? higher speed or more grade?
welp, i weighed 250lbs 3 years ago, and wen to 180lbs within 1/2 year. it was actually part of a bet, so i actually had hydrostatic testing done before and after as part of that bet. went from ~27% body fat down to ~12%.
since then i've gained fitness and started doing more serious training, so i did VO2 testing as well. ended up @ 6% body fat, with a anaerobic threshold @ 149bpm. forgot the actual VO2 value.
anyway, enough about me... reason i mention this is because through VO2 testing you learn that heart rate is basically proportional to energy consumed. that means that you can estimate your calorie consumption most accurately by checking your heart rate. if you want an absolute figure, you'll need to do the VO2 testing, as metabolism varies wildly amongst people. however, relatively speaking, if your heart is beating faster, you are consuming more calories.
so, to answer your question, just measure your heart rate as you raise inclination or as you increase speed. the faster your heart beats, the more calories you are consuming. that is, if that is your only concern.
of course, if you are trying to build muscle, it gets more complicated, because as you cross the anaerobic threshold you begin to metabolize muscle.
anyway, if you want more advice, let me know. and just fyi, i lost that bet amazingly. but i did gain tremendous health. blood pressure dropped dramatically. felt like superman all day long. it was incredible. my VO2 level was actually above the extremely fit scale after 2-3 years.
good luck.
Old Oct 24, 2008 | 07:57 PM
Zomax's Avatar
In my experience with patients, diet plays a larger role than exercise in losing excess pounds. I'm not saying exercise isn't important, but it takes hours to burn off a Whopper with cheese.
Old Oct 24, 2008 | 09:31 PM
DougEFresh's Avatar
heart rate and diet are key.
-Doug
Old Oct 24, 2008 | 10:55 PM
jdmfbpsi's Avatar
in my experience... diet is more important than exercise. Exercise is important in keeping up your energy levels and helping you stay active. Snacking healthy and eating right complement this. If you are trying to burn calories effectively, mix up your routine! Your body gets too used to the same exercises... "muscle memory". For cardio, I start out walking and running on the treadmill. When I'm running, I do intervals of 1:30 minutes at one speed and then :30 minutes a little faster. I've read around and have heard people say that intervals is awesome for burning calories. Don't push yourself too hard, but work up a sweat. I follow through with time on an elliptical, cross-trainer, weights, etc.
What somebody does for their routine might not be right for you and your goals at all. But be persistent and stay motived! The hotties at the gym motivate me.
Old Oct 24, 2008 | 11:24 PM
Orpheus's Avatar
2/3 of one hour actually. @ anaerobic threshold, i burn ~1300 kcal/hr, as measured at the lab. pro athletes will burn much more than I.
but i agree... you cannot do this without dieting, unless you want to risk heavy injury and extreme muscle astrophe.
Kyushin
Mar 23, 2010 11:54 AM
Ks320
Aug 6, 2008 03:20 PM
REVZ TO9
Jan 22, 2007 08:11 AM
dyhppy
Nov 7, 2006 08:11 PM
Purple_sky
Dec 6, 2005 06:55 AM
