What mobile service to you use? And what are the pros/cons?
Old Apr 26, 2004 | 10:03 AM
Daniel L's Avatar
Just depends on where you are. Ask local people. Girlfriend with verizon hates it here.
Old Apr 26, 2004 | 10:06 AM
rallykid's Avatar
Verizon for me, I have been with them under Cellular One/Airtouch/Verizon since 1991 and I would never switch to another company. Check out www.wirelessadvisor.com and you will get all of the info you need. howardforums.com is ok if you can put up with the childishness, flames, and holier than thou attitudes.
Old Apr 26, 2004 | 10:20 AM
ninethreeeleven's Avatar
At my house Sprint does not work so thats out of the question. I use Verizon, but I might change to Nextel.
Old Apr 26, 2004 | 12:00 PM
PeaceLove&S2K's Avatar
I use T-Mobile. They have pretty good coverage here. One of T-Mobile's strengths is that since they use GSM, you can (theoretically) get coverage virtually everywhere in the world (GSM is the standard everywhere except in the U.S. and Japan). I'm not sure if that's important to you though.
Cingular also has GSM phones, by the way, as does AT&T Wireless, though the consensus is to stay as far as possible away from AT&T.
Old Apr 26, 2004 | 12:52 PM
rallykid's Avatar
The only problem with GSM is coverage pretty much sucks once you get outside of a major city. If you travel to large cities and fly all the time then you should be fine, but if you spend a lot of time outside of major metropolitan areas, stay far away from GSM.
For an example, HERE is T-Mobiles national coverage (the red area, the pink is roaming, the tan is no coverage at all).
To compare HERE is Verizons home coverage area (view the Americas choice map).
There are a few areas that you are roaming with Verizon but the coverage blows just about everyone away. Verizon is a little more expensive than the other brands out there, but you have to ask yourself if you would rather pay $10 more per month for a phone that is going to work when and where you need it or save a couple of bucks and have a phone that has no service when you need it most. Like broken down on the side of the road in the middle of nowhere at 3 A.M.
Old Apr 26, 2004 | 01:23 PM
steve c's Avatar
In terms of network coverage and national spectrum licenses, Sprint PCS is still the leader.
Old Apr 26, 2004 | 01:27 PM
A2DaZ's Avatar
Verizon all the way, great service. Always had service with them since the GTE and Bell Atlantic days....
Old Apr 26, 2004 | 02:27 PM
dkhl's Avatar
wow, steve c, took you a while to show up.. i was starting to get worried that you wouldn't show up.
Who cares how much licenses a company holds, it is how many they actually can afford to light up. If that is true that Sprint is the national leader in coverage... i guess all those people who complain about sprint must be smoking bad crack huh...
Old Apr 27, 2004 | 08:38 PM
dkhl's Avatar
The numbers are finally in:
AT&T --> loss of 367,000 customers, churn 3.7%
Cingular --> gain of 554,000 customers, churn 2.7%
Sprint --> gain of 414,000 customers, churn 2.9%
Verizon --> gain of 1,400,000 customers, churn of 1.6%
Wahoo!!!
Old Apr 27, 2004 | 08:56 PM
S2020's Avatar
so many holes in Sprint coverage area.
Such bad customer service.
