why are some freeway onramps asphault and the freeway concrete?
Old Feb 12, 2003 | 07:50 PM
Ludatic's Avatar
Default why are some freeway onramps asphault and the freeway concrete?
anyone know why? i know not all of em are like that but there are some... anyone know if its a scientific reason or just financial or what?
*shrug*
its for school if u're wondering why i'm asking
Old Feb 13, 2003 | 05:45 AM
WestSideBilly's Avatar
Cost - Asphalt is cheap and quicker to build.
Old Feb 13, 2003 | 05:56 AM
JonBoy's Avatar
Purely financial. In my economics class, the prof related how the original deal for building the majority of freeways in certain cities was calculated using incorrect values (or not taking maintenance costs or something like that into account) and so concrete came out as the "best choice" for the material. Later it was shown that an error(s) had been made and that asphalt was/is actually cheaper. So, now asphalt is used where possible.
Physical reasons do exist, as concrete is harder and should last longer, but also cracks more easily (asphalt is more ductile, allowing it to bend and mold better) and therefore will tend to require repairs if the ground shifts or there is a lot of impact on it. We could never use concrete here in Canada in most places, as frost and ground heaves would rapidly destroy it.
Old Feb 13, 2003 | 07:25 AM
Konrad's Avatar
The way most roads are built now are concrete sub layer and asphalt top. It makes the best economical sense.
The concrete lasts but is expensive.
Asphalt is cheap but erodes easier.
Asphalt is recyclable and can be scrapped up and reused.
Therefore, use less concrete by only using it as the foundation and place reusable asphalt as the top layer.
Konrad
Old Feb 13, 2003 | 07:45 AM
redleader's Avatar
I should point out that the word "concrete" basically describes a mixture of cement/water/aggregate. its the CEMENT being used that makes for the two different paving materials.
Portland Concrete Cement (commonly referred to as PCC) is the lighter colored stuff that you are all referring to as "concrete"
Asphalt Cement (commonly referred to as AC) is the black stuff you are all calling "asphalt"
AC is used in the construction of traffic lanes, auxiliary lanes, ramps, parking areas, frontage roads, and shoulders. AC pavement adjusts to limited amounts of differential settlement. It's easily repaired, and add'l thicknesses can be placed at any time to withstand increased usage and loading. Over time, its nonskid properties do not significantly deteriorate. However, as the asphalt oxidizes, it loses some of its flexibility and cohesion, often requiring resurfacing sooner than would be needed with PCC. Asphalt concrete is not normally chosen where water is expected to permeate the surface layer.
PCC is the most common form of rigid pavement because of its excellent durability and long service life. Its raw materials are readily available and reasonably inexpensive, it is easily formed, it withstands expposure to water w/o deterioration, and is recyclable. The primary disadvantages of PCC pavement are that it can lose its original nonskid surface over time, it must be used with an even subgrade and only where uniform settling is expected, and it may rise and fall at transverse joints.
Old Feb 13, 2003 | 08:13 AM
JonBoy's Avatar
Either you work with this stuff a lot or else you copied that out of a book or website!
Good correction on "cement", though - you are quite right.
Old Feb 13, 2003 | 09:03 AM
redleader's Avatar
yeah, I'm a Civil Engineer here in CA and that text I wrote actually came ouf of the Civil Engineering reference manual I keep on my desk. And no I didn't get copyright permission..he he he
Old Feb 13, 2003 | 09:45 AM
JonBoy's Avatar
Ah ha. No wonder it was spot on and well-worded. That said, I don't doubt that you could rattle that stuff off the top of your head awfully well.
Old Feb 13, 2003 | 11:10 AM
redleader's Avatar
if I had to do it in my own words, it would probably sound something like this:
we pave with asphalt because it is cool. I like it.
Old Feb 13, 2003 | 11:35 AM
alexf20c's Avatar
flipman
Feb 9, 2008 12:17 PM
SRTfourbanger
Feb 15, 2007 02:32 PM
I dream of S
Jun 1, 2004 10:54 PM
Eze8199
Aug 21, 2001 04:22 AM
