crazy offsets only...
Old Mar 2, 2009 | 12:45 PM
  #1311
SiR Mikey's Avatar
Originally Posted by second2none,Mar 2 2009, 12:57 PM
Are you sure? Camber can go up as high as -6.0 in the rears.
My car is dumped and maxed out at -4.7 in the rear
Old Mar 2, 2009 | 01:13 PM
  #1312
alexisthemovie's Avatar
then you aren't as "dumped" as others. I have pretty close to -6 in the back of mine. TJ is at -6.
Old Mar 2, 2009 | 01:23 PM
  #1313
SiR Mikey's Avatar
It's dumped
front.jpg?t=1236032463
Old Mar 2, 2009 | 01:44 PM
  #1314
BSeriouS's Avatar
Originally Posted by SiR Mikey,Mar 2 2009, 02:23 PM
It's dumped.
Not dumped enough. Our stance is at the point where we are tucking more than half of the rear tire's profile. The lower you go, the more negative camber you can get out of it in a sense.
IE.
Old Mar 2, 2009 | 01:50 PM
  #1315
second2none's Avatar
Nope, I'm at -5.2 on both sides and looking to go to -6.0 because I'm still rubbing on hard bumps/turns.
Old Mar 3, 2009 | 06:35 AM
  #1316
JPRICE!'s Avatar
i duno what im at, but my buddy clubs are as low as they will go in the rear. thats wierd bec when we did it it wouldnt take any more adjustment and its def not at 6 deg lol
Old Mar 3, 2009 | 07:04 AM
  #1317
It will, bring it to a different alignment guy.
Old Mar 3, 2009 | 07:06 AM
  #1318
JPRICE!'s Avatar
well i plan on putting the 235's on it then going from there, if i dont have to run much camber it would be better, i dont wana go through tires too fast
Old Mar 5, 2009 | 05:55 AM
  #1319
pch's Avatar
pch
Originally Posted by silentdancer,Feb 18 2009, 12:21 PM
Do you have any front shots with the wheels being straight? I would like to see how aggresive and how much camber is noticable on the front wheels. Also do you feel that you would of been better off with 245's in the rear then the 255's? Or are you satisfied with the 255's?
Did you remove the inner fender well liner in the front?
Old Mar 5, 2009 | 08:32 AM
  #1320
PureSportsDriver's Avatar
A friend of mine is deciding on what offset wheels to get for his S2000. He wants SSR type Cs or Type Fs. What kind of aggressive offsets can be run on this car?
He is thinking of 17 x 9 +36 offset all around? What do people think of this size? Any feedback or recommendations are welcome!
Type Cs
