crazy offsets only...
Originally Posted by starbai,Apr 19 2010, 01:42 PM
You can get the type with the pressed in studs if you do 15mm or is that going to be too thick for your goals?
Originally Posted by gabster,Apr 19 2010, 10:49 AM
What would be the proper procedure in replacing the studs "safely"?
thanks
thanks
I just replaced all of my front wheel studs a couple of weeks ago.
Originally Posted by alexisthemovie,Apr 19 2010, 01:50 PM
you're talking about 15mm and 20mm which you can buy with built in studs
Originally Posted by alexisthemovie,Apr 19 2010, 02:51 PM
how does giving you camber specs save you money?
shitty example I know, but i think u can see where I'm going with it... if someone is trying to gain a certain look to the stance, the camber setting is an integral part of that equation... right now i've got really weak fitment on my ghetto wheels, i'm trying different spacers/camber settings to get it to work how i'd like...
if I had exact specs to all these things, i would know exactly what size spacer i need therefore buying only ones set, and only have to get ONE alignment lol
