crazy offsets only...
Old Apr 19, 2010 | 10:30 AM
  #4691
starbai's Avatar
This thread needs camber settings in the specs
Old Apr 19, 2010 | 10:31 AM
  #4692
starbai's Avatar
Originally Posted by hammer.time,Apr 19 2010, 01:39 PM
do it yourself its not hard to replace the studs at all. Take wheel off, move the caliper, and remove rotor. Tap the old studs out and then slide the new ones in its place. Use an open ended lug nut to pull them into place, tapered side facing out.
I did it on my g35 will take maybe an hour or two depending on how fast you can remove and assemble everything.
that was my old method of doing this... but people have told me it can really mess up the wheel bearing and other compontents of the suspension to wale on the lugs with a 4lb sledge to knock em' out of the hub.
Old Apr 19, 2010 | 10:32 AM
  #4693
alexisthemovie's Avatar
Originally Posted by gabster,Apr 19 2010, 10:29 AM
True, but that's plus the labor in replacing longer studs, how much more would that run for??
why would you need to replace your studs?...
Old Apr 19, 2010 | 10:34 AM
  #4694
but then it's too easy
Old Apr 19, 2010 | 10:37 AM
  #4695
inactiveuser1114's Avatar
because i would need longer studs when adding wheel spacers (my post is a few replys back)
  #4696
starbai's Avatar
yea who wants to save fellow members $$ on the trial/error anyways
Old Apr 19, 2010 | 10:38 AM
  #4697
JHooby's Avatar
Originally Posted by tsukubaSpec,Apr 18 2010, 03:27 PM
is that a Replica sidestrake?
would like to know.
Old Apr 19, 2010 | 10:42 AM
  #4698
starbai's Avatar
You can get the type with the pressed in studs if you do 15mm or is that going to be too thick for your goals?
Old Apr 19, 2010 | 10:49 AM
  #4699
What would be the proper procedure in replacing the studs "safely"?
thanks
Old Apr 19, 2010 | 10:50 AM
  #4700
you're talking about 15mm and 20mm which you can buy with built in studs
