crazy offsets only...
Originally Posted by alexisthemovie' timestamp='1308273698' post='20691140
[quote name='ALWAYS_SLAMMED' timestamp='1308265157' post='20690773']
[quote name='alexisthemovie' timestamp='1308255055' post='20690227']
[quote name='ALWAYS_SLAMMED' timestamp='1308199410' post='20687572']
[quote name='alexisthemovie' timestamp='1308188895' post='20687186']
[quote name='ALWAYS_SLAMMED' timestamp='1308176416' post='20686650']
LMAO....someone actually gave me negattive rep for a comment that had no maliciousness to it at all.
I could draw you a diagram, but it would take forever. I'm not saying anyone is wrong, but since the pivot point is at the bottom you will see less improvement in the gap up top than at the bottom. If you had adjustable upper control arms or spc joints however you would see a greater diffrence in closing the upper gap.
Although you will see more of a difference in the front than the rear and I have yet to figure out why.
[/quote]
Can you explain your theory? It still doesn't make sense to me.
You can see a bigger difference in clearance in the front because the stock adjustment is fairly limited (I got -6.4 out of my factory rear and -3.6 out of my factory front adjustment). The SPC joints can add a lot of camber by just sliding the ball joint in, but once you push the toe out to compensate (Toe adjustment is on the bottom), you lose a lot of that clearance. To me, it's the same, but perhaps the LCA adjustment causes the car to lower more when you camber more and that's where you're finding your difference in clearance.
[/quote]
This is true.
I cant explain it on here but you can do it with a pencil(the hub) and some pennies(control arms).
1.Two penies both top(upper arm) and bottom(lower arm) and the pencil is perfectly vertical. Draw a line.
2.Add a pennie to the bottom(factory adjustment). Draw a line.
3.Now return the original 2 pennies to the bottom and remove a pennie from the top(spc or equivalent). Draw a line.
The amount of camber remains the same, but the first line is further out.
If this confuses the crap out of you I understand....
.[/quote]
Unless I am picturing this wrong, you'd end up with 2 parallel slanted lines...
I still don't buy it. When you pull the top in, the bottom is effectively pushed out. Same thing when you do the opposite.
[/quote]
Correct two parralel lines, but not overlapping(that tells you that the same amount of change applied to both upper or lower has different effects). As you can see, you yeild more clearance trough removing the upper pennie. So if you wanted to remove upper gap as in the s2k with the RS's, it would be more effectively acheived via the upper control arm.
I deleted my posts so I dont get shot in here.
[/quote]
They're parallel meaning that he same amount of adjustment (whether top or bottom) has the same effect, otherwise they would NOT be parallel. To flush out the s2000 on RS', he just needs to take out camber period. It doesn't matter whether it's from the top or bottom. What if he doesn't even have SPC ball joints?
[/img]
[/img]
