Winter tires
Hey all. I was thinking about putting winter tires on by rears only. The tires I see at tirerack are 16s. Has nayone ever changed out your rear tires only for winter? and if so, what tires do you suggest.
(please don't tell me to do a search, i did one and came up with some good ideas)
When I was young and not so smart (like a gazillion years ago), I ran rear snow tires only on a Mustang. It was extremely dangerous, but I didn't know any better and I thought me and my car were invincible. I turned out that I was just plain lucky.
You really need snow tires for the front because you need to be able to stop and turn. Your rears won't help much in these departments.
Bridgestone Blizzak LM-22's make a good compromise between snow drip and dry road performance but they are somewhat pricey. Blizzak WS-50's are a bit cheaper but they are more aggressive snow tires and handle less well in the dry. Almost any dedicate snow tire will get you by, even the cheapest ones you can find that will fit. Getting 4 of these is by far much better than just getting good ones for the rears alone.
I am not cheap! Well. not always. Do I need to put 17s on the back and 16s on the front? My tread is low on the back anyway. I figured if I throw some winters on in mid december, i could hold off till spring for my new rears.
thanks for the help fellas.
ray
ray
Are you going to get a separate set of wheels for the snow tires? If not, then just get 16" snows. You shouldn't be mixing 16" and 17" front and rear. Also, if you are getting new wheels, you should see which are more expensive - 16" or 17" snow tires.
Originally posted by ROGUE3308
i am putting on 4 winter tires.
thanks for the help.
