Oklahoma S2000 Owners Oklahoma S2000 Community
anybody know how to replace the rear right axle?
Old May 8, 2011 | 08:52 AM
Hrshybr192's Avatar
Default anybody know how to replace the rear right axle?
i recently got in an accident with my S i need to replace my front right and rear right hub assembly and the rear right axle, i think i can do the hubs but im not to sure about the axle. and anybody know where i can get a door shell and fender for cheap lol
-Hasibur
Old May 8, 2011 | 10:49 AM
spets's Avatar
Since you're replacing the hubs, the axle should just pull out, I would think once you undo the knuckle.
I've never replaced them though so I don't know.
Old May 9, 2011 | 01:50 AM
TonyTransformer's Avatar
step 1 take off the big 36mm nut off of the axle which is located in the center of your hub
step 2 unbolt the abs sensor harnesss from the top arm
step 3 take out the cotter pin and unbolt the castle nut that holds in the lower A-arm then pop it out.
step 4 unbolt the six 14mm bolts and nuts that connect the other end of the axle to the diff
step 5 take a screw driver and a mallet to hit out the axle. dont bang on it but easily tap on it
it should just come out with a tug and if it dont then wedge a flat head in between the axle and diff and pry it out
hit me up if you have any questions
Now just reinstall everything in reverse order.
be real careful when pulling on the hub not to damage the ABS wires. When the axle nuts are retightened, use a hammer and screwdriver to put a new crimp in the nut flange if necessary.
-tony
If i missed anything then please dont flame on this post but feel free to add in some left out instructions/information
solitarycheese
May 26, 2017 11:10 AM
Slammed_s2k
Jul 9, 2015 07:47 PM
miskatcitnamor
Aug 23, 2014 08:27 AM
Daily_Dumped_AP1
Dec 12, 2011 09:23 PM
1a-race
Nov 18, 2002 06:58 PM
