First time DIY's
Old May 27, 2009 | 06:39 AM
ScoobyLai's Avatar
yes that helps alot.
tommy are u off sunday? because i was hoping to do it on sunday since I have the whole day off
Old May 27, 2009 | 08:21 AM
S2Kme's Avatar
Ehh.. I don't think so.. I'm off sat, back to work on sunday.
Old May 27, 2009 | 08:47 AM
ScoobyLai's Avatar
Busy on saturday, gotta go to my sister in laws baby shower... well maybe we can do it today? I am off of school at 1 and have nothing to do so I can pick up the filter and brake fluid to flush it. Let me know.
Old May 27, 2009 | 12:10 PM
s2sik's Avatar
the berk tp measures 63.5 outter diameter, so its a true 60mm pipe on the inside. most test pipes and exhausts that list at 60mm is accounted for the actual outside diameter. this was the conversation i had with berk. good luck. (and berk products and services are quality)
Old May 27, 2009 | 01:19 PM
triddle's Avatar
Check this out for a clutch bleed DIY: Clutch Bleed Howto
I changed my clutch master cylinder a while back and wound up replacing all of the fluid in the process which put quite a bit of air in the hydraulic system. If you let the reservoir level get too low I think you may run into a similar problem as I did: even after bleeding the clutch the engagement point was low and the clutch pedal felt "soft." While the linked thread says to pump the clutch 3-4 times to restore pressure in the system it did not do the trick for me. On another thread on this forum I found a suggestion for pumping the clutch 50 times - that's what it took for me to get full pedal feel and a normally high engagement point with out any other adjustments on the hydraulic system. I thought I'd done something wrong initially but it's been 3,000 miles now and the clutch still operates wonderfully.
Good luck and wrenching on my S is one of the most frustrating and satisfying parts of owning it.
Old May 27, 2009 | 05:44 PM
ScoobyLai's Avatar
So the berk is really a 60mm? hmmm it sounds like I will get one then. Has anyone seen really good increase in horsepower? I want to increase hp but not go broke lol. Well thanks for all the help guys. I did it! With help from s2kme
Old May 28, 2009 | 06:20 PM
s2sik's Avatar
"really good" is "really subjective"
i think its one of the best bang for your buck mods if you dont mind burning a hole in the ozone. it helps throttle response, is a decent chunk lighter, you should be able to get a couple whp out of it, and you will surely smell like gas everywhere you go.
Axehead
Jul 27, 2011 09:48 AM
03BlkS2k
Sep 20, 2010 04:10 PM
Bliss@5200
Oct 4, 2009 10:39 PM
RobJ1
Apr 21, 2009 11:59 AM
soundzero
Mar 4, 2006 06:27 PM
