Help Needed! - Grinding Noise
Old Jul 9, 2011 | 02:05 PM
DragonMahn's Avatar
Default Help Needed! - Grinding Noise
So when i'm driving my S2000 and i let go of the accelerator it makes a grinding noise underneath me, any ideas of what could it be?
Perhaps i need a new clutch?
Old Jul 9, 2011 | 02:11 PM
id003's Avatar
Well your in a 00' like me, most likely clutch buzz. What RPM range does it occur?
Clutch buzz is harmless, and irritating to some.
Old Jul 9, 2011 | 02:22 PM
DragonMahn's Avatar
Any RPM
Old Jul 9, 2011 | 02:31 PM
exodusx7x's Avatar
A grinding noise? Can you find a similar video clip on YouTube? A clutch buzz and a grind are to separate things. Car acting different at all?
Old Jul 9, 2011 | 02:51 PM
DragonMahn's Avatar
i really cant find a video but it sounds like a buzz i suppose. It doesnt act different at all, i just need to know if i need to change clutch to fix it.
Old Jul 9, 2011 | 07:44 PM
EVAN&MONICA's Avatar
Description sounds like clutch buzz. If thats what it is be happy! Clutch buzz is 100% harmless, and its not very expensive to correct.
Is this what your hearing?
http://www.youtube.com/watch?v=2GkWdHfFkjk
Old Jul 10, 2011 | 02:02 PM
#172CR's Avatar
I agree it sounds like that could be the issue.
Old Jul 11, 2011 | 07:20 AM
S20004ME_PDX's Avatar
The AP1 clutch buzz only occur in very specific rpm range and condition, if you're saying its at all RPM, I don't think its the clutch buzz.
I would take it to a mechanic or at least take a video yourself and link it here once its up on Youtube.
Old Jul 11, 2011 | 09:18 AM
cdelena's Avatar
All 2000 and most 20001 models that have the original clutch have a friction disk with springs that rattle in response to vibrations from the transmission during deceleration. Some are much worse than others and the only fix is a later model FD which is replaced in a clutch job. The clutch replacement in this car is relatively expensive usually running $700 to $1000. If you can stand the noise there is no other damage from the problem.
vla
May 10, 2014 10:37 PM
S2Kaz06
Mar 20, 2012 11:56 PM
bbak11010
May 25, 2009 05:19 PM
AROD
Dec 8, 2006 07:05 AM
axiom
Aug 21, 2002 06:48 AM
