ball joint install help.
couple of things....
first off if you havent seen this its pretty good. even if you just browse the pik-tars
https://robrobinette.com/S2000BallJoint.htm
second, if you need a ball joint press and thats all thats holding you back then auto zone rents them and then gives you back all the money when you return the tool.
third, if you want to use a press but dont have one self serve garage in kent has a press you can "rent" for a nominal fee by the hour. Also theres another one near kirkland. if you google "Self serve garage" i think its like stews or stewarts in the name.
this assumes you WANT to do this yourself because i totally didnt answer your actual question
