Engine management that will pass SMOG test
Old Apr 28, 2008 | 08:47 AM
street_ruler's Avatar
Default Engine management that will pass SMOG test
are there any aftermarket ECU's that i can use to get a good tune with a CTSC and still pass a smog test? for background its a stock 04 and it needs to pass washington state emissions
Old Apr 28, 2008 | 12:37 PM
RAIN H8R's Avatar
Well, a car equipped with just a comptech kit should pass emissions. AEM EMS does not, hondata K-Pro does, and greddy emanage will (i do not recommend the emanage)
Old Apr 28, 2008 | 01:43 PM
the e-manage is a piggy back right? so the stock ecu re-adjusts and tunes out the emanage settings correct?
i guess do i really need to get an engine management system to just run stock boost on a ctsc? can i get away with just using their management?
Old Apr 28, 2008 | 01:49 PM
jerrypeterson's Avatar
Are you planning to modify the Comptech Supercharger kit in any way? The stock ECU could be used for emissions testing and will pass in the default configuration. The DMV is simply plugging into the ODB2 port and checking for error codes. So if the CEL light is off and the port is working, you should pass.
Old Apr 28, 2008 | 08:16 PM
i plan on running stock boost on the CTSC and not playing with it really
Old Apr 29, 2008 | 12:09 AM
Did you get the Comptech ESM along with the kit? Install the ESM using T-Taps for all but one of the leads. Pull the leads out of the T-Taps and solder or crimp a bridge wire for the white-yellow wire to run a stand alone ECU. This will allow you to swap back to the stock ECU "as needed."
Old Apr 29, 2008 | 05:53 AM
you sir are a god amongst men.
clarkster009
Oct 21, 2010 09:44 AM
lvd1102
Oct 6, 2009 06:05 PM
mr_grand_prix
Oct 15, 2007 06:39 PM
nightcrawler7188
Jul 27, 2007 06:56 AM
ronaldng0809
Jul 26, 2007 10:48 AM
