CTSC/AC and piggyback
Old Jul 25, 2007 | 02:56 PM
nightcrawler7188's Avatar
Default CTSC/AC and piggyback
i've been told by many on this forum that if i were planning on keeping stock boost with my current header/test pipe/exhaust setup, it'd be best for me to get an eManage to tune it if it were to run too lean. but today, one of the tuners at inlinePRO told me in person that since the comptech has the ESM as part of the kit, i shouldn't get the eManage, because having 2 piggybacks working together (comptech ESM and eManage) would never allow the car to drive smoothly as i would desire. is this the case?
Old Jul 25, 2007 | 03:13 PM
waltk88's Avatar
The ESM is a voltage clamp that hides boost from the stock ECU, it's not a piggyback.
Old Jul 25, 2007 | 03:24 PM
^^thought so!
thanks.
Old Jul 26, 2007 | 06:05 AM
pdexta's Avatar
The emanage can be used to clamp the voltage, you will no longer need the esm.
Old Jul 26, 2007 | 08:05 PM
CourageOO7's Avatar
I have been struggling with this exact problem. The people at Inline are correct. I suggest a stand alone system.
Old Jul 26, 2007 | 08:09 PM
Johnny Sack's Avatar
so why dont you just ditch the ESM and just run the emanage?
Old Jul 26, 2007 | 09:06 PM
^^i don't have the kit on yet. i also thought that once you have the kit on, you must have the ESM on as well.
Old Jul 27, 2007 | 06:18 AM
WashabiS2K's Avatar
you can drive the car without the ESM, but if your ECU detects boost (on stock boost, probably up around 4.5k rpm? not sure) your ECU will go into limp mode. but it is completely driveable without the ESM, as long as you are under 4k rpm all the time.
Old Jul 27, 2007 | 06:56 AM
doesnt EU have a feature that does the same thing as the esm?
vader1
Jun 4, 2012 02:41 PM
lvd1102
Oct 6, 2009 06:05 PM
street_ruler
Apr 29, 2008 05:53 AM
kylemonster85
Jul 9, 2007 03:24 PM
Chitah831
Aug 20, 2006 10:16 AM
