help comtech esm
Old Apr 30, 2007 | 03:50 PM
ronaldng0809's Avatar
Default help comtech esm
hello, i just bought a used comptech supercharger kit from one of the member here. but it didnt come with the factory comptech esm. And i know is hard to get it now. Anyone knows what i can get to replace it. but it must pass the emission test in GA, and i cant afford the aem one, thanks .
Old Apr 30, 2007 | 04:13 PM
dims2k's Avatar
buy the e-manage
Old Apr 30, 2007 | 05:09 PM
so the greddy e manage can replace the comptect esm.? and it will pass emission too?? thanks
Old Apr 30, 2007 | 05:16 PM
sorry, i'm new on supercharger kit. can anyone give me the model or item numbers for the greddy e manage. i dont want to get the wrong one. thanks
Old Apr 30, 2007 | 07:56 PM
73Zero's Avatar
IMO, you don't necessarily need the eManage, if all your looking for is a replacement for the Comptech ESM. Basically, the Comptech ESM is a "voltage clamp" for the MAP sensor, which "clamps" the MAP sensor's output voltage (to the ECU) at 2.93v to help prevent the ECU from "seeing" boost. As a replacement, you can try one of these: http://www.splitsec.com/products/clamps.htm
(BTW, the ESM clamp setting of 2.93v is what the Comptech instructions state.)
I hope this helps...
Old May 1, 2007 | 11:57 AM
hey so if i buy the greddy manage. is there are anything that i need to get to make them work, or just plug and play? thanks
Old May 1, 2007 | 12:21 PM
stphotographer's Avatar
You'll need a harness go to boomslang.us
You'll also need the software if your tuner does not have it. You can get the software and cable from a vendor that sells the emanage.
Old Jul 26, 2007 | 10:48 AM
Inlands2k's Avatar
Does anyone know or tried anyone of those clamps on the site? If so which one would be best for a Comptech SC s2k. thanks
s2konroids
Sep 24, 2010 02:51 PM
s2kadrenalin
Jan 14, 2008 11:30 PM
kylemonster85
Aug 2, 2007 05:37 PM
kylemonster85
Jul 4, 2007 06:49 PM
home13oy75
Aug 31, 2004 12:39 PM
