Engine Rattle
Originally Posted by RT,Jun 26 2008, 10:59 AM
I left mine making noise at start-up for about 20k miles and it eventually started making the noise at times other than start-up so I got scared and changed it.
Mike, I'm not sure it's 100% a spring issue, might be combined with a sealing deal too since there are no "seals" per se and excessive bore clearances may play a part.
Anyway, IMO the TCT should have nothing to do with a noise that is only heard at 3-4000 RPMs while decelerating.
Could still be some portion of the heat shield, either the devider or on the header. There is several small bolts that get lose/ stipped and crack from vibration. I have had this happen a few times. I just finally took my heat shield off. Found a crack around one of the bolts on the manifold sheild last week, though it isn't making any noise.
Well, the spring goes first. Perhaps the rest goes over time? Or perhaps it is an initial amount of wear that contributes to the spring failing? Probably most people replace it while it's still a just start-up issue.
The noise for me now seems to be getting worse. Its starting making it in 3rd gear about 3k RPMs. It also does it in reverse now too. Once I shift into neutral it quits. But I think I am going to take it in since it is driving me crazy.
senor_flojo
38
Apr 21, 2011 01:21 PM
tdots2k
May 5, 2010 06:36 AM
