HELP!
Old Oct 13, 2005 | 02:40 PM
kpxguy411's Avatar
Default HELP!
Lately since the weather has been getting colder when I start up my car in the morning it has some trouble starting and sometimes takes a little longer than normal to turn over. A friend told me this could mean that I need new spark plugs. Would an engine block heater fix this problem? Any help or suggestions are appreciated. Thanks!!
Old Oct 13, 2005 | 03:01 PM
mikegarrison's Avatar
"Engine block heater"? That's for -20, not 40.
Actually my guess would be the battery. Are you still on your original battery?
Optikal's Avatar
I think it is just the ECU having problems adapting to the colder weather. Mine had a rough start for a little bit but the ECU finally figured it out.
Just give it some time and check back on the forum later.
Old Oct 13, 2005 | 03:08 PM
kpxguy411's Avatar
Oh ok, I saw the engine block heater on hardtopguy.com, but the description didn't give very much information. Just sounded like it might be able to alleviate my problem.
I bought the car used in the middle of March and as far as I know it is still on the original battery.
Old Oct 13, 2005 | 03:38 PM
chikai's Avatar
I reset my ECU and my car doesn't sputter on start up. It also helped my MPG. Something to think about...
Old Oct 13, 2005 | 04:24 PM
kpxguy411's Avatar
What steps did you take to 'reset your ECU'? I've heard a few different ways ...
Old Oct 13, 2005 | 04:51 PM
Spa4eva's Avatar
Dude sounds like your battery. My car does that as well when it get really cold. Don't sweat it and if it becomes more frequent buy a new battery and see if it continues to happen.
Battery at costco should be $45 bucks and I believe they give you 5 or 10 bucks back if you give them your battery. It's a cheap fix.
Old Oct 13, 2005 | 06:28 PM
PWRMKR's Avatar
I have had the same problem lately. I'm in agreement with Optikal on this one. The ECU is learning.
My original battery still has the blue ring with the red dot.
BTW, I bought and installed the OEM block heater. It was my Fifth mod. I have never used it.
Old Oct 13, 2005 | 06:50 PM
chikai's Avatar
It's easy...pull one fuse.
See instructions below:
https://www.s2ki.com/forums/index.php?showtopic=183490
And it doesn't reset your stereo...so your KUBE 93 radio station will stay in your presets.
Old Oct 13, 2005 | 08:29 PM
vAnt's Avatar
??? lol what was that sposed to mean? xD
