HELP!
Old Oct 14, 2005 | 02:33 PM
  #21
mikegarrison's Avatar
Originally Posted by jerrypeterson,Oct 14 2005, 02:32 PM
A block heater would not improve cold weather starting performance. A block heater would keep the coolant in the engine from freezing. Coolant freezing is a bad thing because water expands when it transitions to a solid. That expansion would crack the engine block.
Actually, it does help with starting. But only when things are so cold that the lubrication gets thick. This would be well below zero F. In places like Alaska or the frigid wasteland that xviper lives in, people routinely plug their block heaters in overnight to make sure the oil will flow in the morning. It also protects against the coolant freezing.
And if the coolant freezes, the block does not crack. Instead, plugs in the block (called "freeze plugs") will sacrifice themselves first. Having the freeze plugs pop out is bad, but not as bad as if they weren't there (in which case the block really would crack).
Old Oct 14, 2005 | 03:04 PM
  #22
jerrypeterson's Avatar
Does this mean there is a market 0-20 weight motor oil afterall?
I have pondered the purpose of those seemingly useless plugs. Cool.
Old Oct 14, 2005 | 03:44 PM
  #23
RT's Avatar
RT
yeah, just pound'em back in with a 2x4 when things thaw out (you do it quick enough and you don't even need to add water afterwards)
Old Oct 14, 2005 | 07:41 PM
  #24
PWRMKR's Avatar
Originally Posted by WRS2K,Oct 14 2005, 07:26 AM
Yo marky mark,
And as for this ECU... y'all make it sound like it's some sort of wizard of OZ taking in all this info and sorting it out H.A.L. style. i read of peeps saying ECU noticeably increased butt dyno power....
Old Oct 14, 2005 | 08:53 PM
  #25
Now THAT'S some good stuff, PWR.
kimimila
Mar 29, 2013 08:12 PM
CiderBoy
Jan 22, 2007 05:02 AM
Monkeyboi
Jan 16, 2007 10:13 PM
REV_29K
15
May 27, 2005 03:06 AM
VR WHAT
May 30, 2002 01:39 PM
