S2k offset question!
Originally Posted by dumped-s2k,Mar 18 2009, 05:26 PM
yep i am a newb s2000junky anything else u wanna say kool guy?
Guess thats a thank you for taking the time to help you from yourself.
Originally Posted by s2000Junky,Mar 19 2009, 09:49 AM
Nah its a good offset with a wheel that wide, only 11mm more then stock.
Ray what was the spec on your 11" wheels/tires. Lets see your pic for comparo just out of curriosity
The wheel is ~17mm further out than AP2 stock wheels. With tires it was necessary to roll the fenders.
They are Fikse 3 piece, no rubs unless i get a good bump in the back. I'll have to defer to RT on the specs, he set it up.
Junky you can look at the same photo cause it's Ray's old car and I only removed the dirt.
Originally Posted by RT,Mar 19 2009, 12:31 PM
no fender rolling involved ....... will rub on inside under large compression only because I increased the bump travel from stock to stay off the bump stops at mad speeds.
Oh thats right someone cut there springs.
How did that effect your toe under that kind of compression? handfull? Guess it would be better then bottoming out in a turn.
Yeah I was going ot say it looked like you still have a good 1/2 of room to play with there on the fender clearence, good enough for an 11"
