Storing the s2000 for the winter
If it is going to be parked for a few months the first gotcha is the fuel tank. I recommend either pumping out the tank or adding fuel stabilizer. Since you are storing the car outside double check your anti-freeze level and solution. It would really suck to start the car in March and realize the block cracked in January. Might be a good time to Shinetsu all the rubber seals too. Run the engine every few weeks during the winter. It would be a good idea to bring the engine up to temperature and recharge the battery. A battery that cycles out probably won't last very long after the fact. Finally, keep the tire pressures up. Just check the pressures when you start the car.
Everyone: Never lower the convertable top if ambient temperatures are below freezing. Expensive things can happen especially if you have a plastic rear window.
I think you'll be fine, DON'T leave the parking brake set and start it up once every other week or so. I've got cars "parked a few months" year round, on a regular basis, and have never had problems due to our extremely mild weather/climate (I believe).
Originally Posted by 124Spider,Oct 28 2008, 09:23 AM
I don't know that I would keep a car cover on the car if the car's going to be outside. It seems to me that that kind of guarantees that your car will never, ever dry.
Originally Posted by Fastfour,Oct 28 2008, 11:11 AM
and will advertise that it is just sitting and noone will ever know that it was broken into. I would look into a storage unit large enough to put a car into.
Might be a good time to Shinetsu all the rubber seals too - What does this mean?
Does anyone know the ballpark for storage?
I will keep the car insured so I can take t out on somewhat decent days.
I just want to preserve the s2000 !! haha
https://www.s2ki.com/forums/index.php?showt...dpost&p=5798519
Shin-etsu grease is the recommended protected for the rubber seals on the S2000. The owners manual recommends applying this product to the door/trunk/hood/top seals once a year to keep the rubber supple and pliable. If you park the car yearly, seems as good as time as any to do the procedure.
Most car insurance companies will drop the rate for a car that is in storage. Whenever you want to drive the car, call the agent and let them know you are taking the car out for a few days. As long as you provide advanced notice you are driving the car most insurance companies will let you do the couple day a month thing without a full charge.
Trailerparktrev
Nov 7, 2011 06:54 AM
Silverstreak HX
Aug 14, 2004 08:59 PM
