Sway bar question and Hello!
Originally Posted by PedalFaster,Oct 21 2009, 09:43 PM
Keep in mind he has aftermarket coilovers with unknown spring rates, so the statements above may no longer be true.
Originally Posted by RT,Oct 21 2009, 10:03 PM
... well Steve-0, the statement above taken alone is out of the true context ....... he was just surprised at my original statement that simply removing a relatively stiff bar from the rear of his car would create an understeer situation ...... which is what will happen if he "simply removes" the ill fitting bar from the rear as he asked. I know you can be very helpful if you want ....... it'd be nice if you actually were
Your car will understeer if you don't run a rear bar.
Your car will have neutral balance if you run the stock rear bar.
Your car will oversteer if you run a stiffer rear bar.
...Which I again say may be incorrect given that his spring rates have changed. That's all that can be said without knowing his spring rates and/or driving his car. Your statements presuppose a baseline which doesn't apply here. The original poster should tell us whether he likes his car's balance, and we can give input on proposed changes based on that.
Edit: Since I'm being called out for being unhelpful (again, unfairly in my opinion), I'll elaborate. Take off the rear bar, drive without one for a while, and decide whether you're happy with the car's balance. If you are, you're done without spending a dime (other than if you pay someone to remove the bar). If you think the car's too pushy, reduce the rear toe-in (if you're running any) and see if that helps. If the car's still too pushy, find a junkyard rear bar and install that. If the car's still too pushy, then something's pretty weird with the setup or you like a really loose car.
Or, if you're not sure if it's loose or pushy, or aren't sure what those terms mean, just take off the rear bar and don't worry about it.
Originally Posted by 124Spider,Oct 22 2009, 09:26 AM
Steve, it's jarring every time I see David's car on your sig....
Originally Posted by kelvin96gsr,Oct 21 2009, 07:28 PM
Welcome come to taco tuesdays at Applebees
You guys are harsh, someone out there (from some strange place) liked this kit enough to spend that kind of money lol, at least this guys was smart enough to pick it up already done at a fraction of the cost, of course after paying to have it removed he wont be saving
And Peddle Faster /RT are both right in their own context. Figuring out what spring rates are on your coilovers will be a helpful factor in deciding which year of rear sway bar to run as 00-01 02-03 04-05 and so on all will have a different tension/handling attribute. trying to keep as close to a 50/50 balance at the limit is what I prefer, if that’s your goal then keep that in mind when selecting.
Originally Posted by PedalFaster,Oct 22 2009, 08:26 AM
Not sure why you're upset by my response or think it's unhelpful -- I actually think it's both more correct and more helpful than your post. You made a absolute statement, which I'll paraphrase:
Or, if you don't know what "loose" and "pushy" mean, just take off the rear bar and call it a day.
Junky, your statement is also overly general. I agree that there's such thing as a car that's too softly sprung. However, without knowing Gerald's spring rates, we don't know for sure if his car will be too soft without a rear bar. There's also actually such thing as a car that's too stiffly sprung as well, so adding more rear bar isn't always a good idea even if more rotation is desired -- it may make the car feel more precise, but it may also compromise rear grip and/or drivability.
Unless a car's setup or handling are utterly screwed up, in my opinion the best way to make setup adjustments is incrementally, relative to the current setup and behavior.
