Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Berk HFC
Old May 26, 2011 | 09:27 PM
drifttube123's Avatar
Default Berk HFC
Hi all, I was wondering if anyone has ever installed a Berk HFC (63.5mm) onto the stock ap1 manifold. The reason I'm asking is because my mechanic installed mine last week and it seems to leak from that connection (fumes in the cabin). He used the stock donut gasket with the stock spring loaded bolts. He said that the stock gasket was not the best fit. I was wondering if anyone used an alternative type of gasket or had any suggestions for this fitment issue(I don't know if it matters but I am running a Toda cat back exhaust).
Thanks in advance
Old May 26, 2011 | 09:46 PM
lltysonll's Avatar
berk usually supplies gaskets with HFC/TP. You will get fumes like most ppl complain about.
Old May 28, 2011 | 12:55 PM
coldrsx's Avatar
I have had both the 63 and now the 70 and had the smell on both until recently with the donut and new bolts all around. It is still faintly there, but basically gone.
Old May 30, 2011 | 05:17 PM
Where did buy the gasket? The dealer wanted 55, online ranged from 20 to 50.
Old May 31, 2011 | 12:15 PM
coldrsx's Avatar
at honda... it was something around 30 if i recall
Old Aug 16, 2011 | 05:10 PM
starchland's Avatar
I think a new gasket may work since it is somewhat of a crush type gasket where the seal is made. Are you sure its not just the stronger smell of a HFC? cuz they do smell a bit stronger than the oem cat just by design.
rodneyyar
May 25, 2018 05:51 PM
Driv300mph
Mar 1, 2012 09:30 PM
vAnt
Oct 14, 2005 11:47 AM
S2kracka
Sep 12, 2005 07:24 PM
Mok
Mar 7, 2004 05:21 PM
