Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Clunking Noise when in Reverse
Old Apr 3, 2005 | 08:55 AM
Calgarian's Avatar
Default Clunking Noise when in Reverse
Has anyone experienced a clunking noise while in reverse. Reminds me of the sound my 1976 Civic would make when the sub frame loosened up. Any ideas?
Old Apr 3, 2005 | 09:01 AM
xviper's Avatar
More details, Ian.
When does this noise happen? When you are "going" into reverse? When you are "in" reverse but not moving? When you are "in" reverse and beginning to move? When you are "in" reverse and moving? How fast? How long? Car after first cold start of the day? Car after it is up to operating temps? Any other details?
Without more to go on, you may as well have one of your service guys take a look at it.
Old Apr 3, 2005 | 09:08 AM
Calgarian's Avatar
I noticed it when I was slowly backing into the garage which is on a small incline. Just one clunk was heard. I'm thinking it could be a loose suspension component, or driveline issue since it happens under load but I'm not sure. It's definitely not the brakes.
Old Apr 3, 2005 | 10:37 AM
xviper's Avatar
If it happens once with the change in direction, it is likely to be the loose hub nut thing. Ask your techs about it. The rear wheel hub nut has been known to need tightening. There is a TSB on this. The nut must be removed, the area lightly greased, the nut put back on BUT with a higher torque. The original torque was 181 lb/ft. The new TSB torque is 220.
Old Apr 3, 2005 | 06:44 PM
Calgarian's Avatar
What a wealth of information. I'll let you know what I find out.
Old Apr 4, 2005 | 07:32 PM
doodlebug's Avatar
maybe related...maybe not....but I can't get my car in to reverese (easily) on cold starts. I need to put it into first gear and then the shift into reverse is ok....any thoughts Dave?
Old Apr 4, 2005 | 08:32 PM
xviper's Avatar
[QUOTE=doodlebug,Apr 4 2005, 08:32 PM] maybe related...maybe not....but I can't get my car in to reverese (easily) on cold starts.
Old Apr 5, 2005 | 05:45 AM
doodlebug's Avatar
Thanks Dave...it's good to know that I am normal (sort of).
tngay510
Feb 3, 2010 07:23 PM
PersianSTud
Dec 1, 2009 05:06 PM
taffyb
Dec 4, 2007 04:03 AM
taffyb
Oct 12, 2007 09:35 AM
SWIFT2000
Mar 16, 2006 05:39 AM
