need tires
interesting. i assume that we all try to keep the overall dia of our wheels the same irregardless of rim size.for street purposes. if i interrept this right :if we had a very small overall dia wheel there would be more torgue required so our revs would need to go up keeping us in the sweet spot of the motor's torque curve. if we have a very large overall dia wheel then we are cruising? not sure if this compares but the change in dia of a dragsters slicks going from a stop to wheel spin.
Vlad, I think your car would look great with bronze wheels, polished lip, dished in the rear... 18's or 19's.
This is purely from a "looks" standpoint.
-SSR Competition
-Volk GT-U
-Volk TE37
-SSR Competition
-Volk GT-U
-Volk TE37
The larger the wheel diameter, or the larger the outside diameter on the tires, the more torque required to spin up the wheel/tire, leaving less torque for forward acceleration. The smaller the wheel diameter, or the smaller the outside diameter of the tires, the less torque required to spin up the wheel/tire, leaving more torque for forward acceleration.
However, if the outside diameter of the tire is smaller, the engine has to be going faster to get the same forward speed (everything else being equal).
Originally Posted by magician' date='Feb 7 2005, 04:50 PM
Mea culpa!
I erred in converting inches to feet. (Sheesh!) I've fixed it.
I know that in the real world, my brother went from (roughly) 24 lb wheels on his Mazda 3, to SSR Competitions (basically one of the lightest wheels available, 12.7 lbs in a 17 x 7.5)... and his car is noticeably quicker now. His savings was about 14 lbs per wheel/tire (he also went with Toyo T1-S' - a very light tire compared to most)... so 14 x 4 x 10 (if the difference is 10 times... I thought it was less, 6 to 8?)... it's like he dropped 560 lbs in static weight... (336 lbs if it were 6 times).
Another way to look at it might be imagining that you have a full tank of gas and a 250 lb passanger... as opposed to having 10 litres in the tank and you're by yourself. Quite a difference there.
Originally Posted by blackS2000' date='Feb 7 2005, 05:36 PM
Don't need to comb...it's all in the GEL
Had the top down today... nice and sunny, feels like spring
Now I am leaning on the SSR's in this link below:
https://www.s2ki.com/forums/index.php?showtopic=259081
I am iffy on the black as it just doesn't stand out. Now black on a black car can look ok, but in my opinion it's just different. I think on a black car, chrome looks best. It has a bit of bling factor to it, but I look at it as having a more clean look. The silver colored rims look better on other colored cars.
I think the Volks that you guys are getting are nice wheels. I like to do things a bit differently, so even SSR black is an option. I like the aggressive 5 spoke look.
Note to admins: There are so many nice pics spread throughout the site and are not included in the gallery section. Catch them before they disappear!
-a smaller diameter wheel with a higher aspect ratio tire to make for the same overall diameter?
-or a larger diameter wheel with a lower aspect ratio tire?
I'm going to guess that metal is heavier than rubber, so a larger wheels puts more of it's weight further away from the axle. We all know that it's easier to spin faster if we can concentrate the weight close to the center. Example being a figure skater. If he/she goes into a spin with arms out, without inputting any more energy, if he/she pulls his arms tightly against his body, the spin increases dramatically. All I'm saying, is that it takes more energy (force or HP, if you like) to spin a bigger wheel fast. Now, the big question that hasn't quite been answered:
Which takes more HP to spin - a) A smaller, but heavier wheel? or b) a larger but lighter wheel that has more of its mass further out from center?
ps. We must make the condition that the wheel/tire diameter remains unchanged so that speedo compensation is not required.
Originally Posted by xviper' date='Feb 7 2005, 05:58 PM
I think you may have this backwards. We must ask ourselves which puts more weight further away from the center of the wheel:
Einstein must be rolling in his grave.
I would still assume that the lighter, larger diameter wheel would be easier to spin. Even if you're comparing a 16 inch 20 lb wheel to an 18 inch 16 lb wheel, most of the weight in either wheel is found in the section which the tire is mounted to (look at the increase in weight even with a CE28N going from a 7.5 inch width to 9 inch width)...
The figure skater could have had a turkey dinner before her competition...
edit - volk ce28n 17 x 7.5 = 13.8 lbs - 17 x 9 = 14.8 lbs
