S2000 Body and Paint Body kits, paint, ding repair and related discussions
corrosion issues
Old Jan 27, 2014 | 04:31 AM
bburnrover's Avatar
Default corrosion issues
I run a 2003 car in silverstone grey its the GT model with hard top.I have an issues with the fact that its rusting like a Merc does over the wheel arches and I keep painting that zinc jelly stuff on which hammerite produce and it seems to get worse. I wonder if getting it filled and resprayed works or does the rust still come back?
Old Jan 27, 2014 | 04:47 AM
Nemi's Avatar
The only way to get rid of the rust completely is to cut off the area that is rusting and weld on new and fresh steel. Sadly
Old Jan 27, 2014 | 09:18 AM
slalom44's Avatar
Top Answer: 1
If you're seeing the paint bubbling up, it's rusting from the inside out. That could be caused by poorly sealed hems (unlikely), plugged weep holes or bad repairs from previous work.
Since there is no such thing as a GT model, I suspect that you may be a troll. I have a daily driven 2003 without a spot of rust.
Old Jan 27, 2014 | 10:23 AM
neuronbob's Avatar
There is a GT model in the UK, and from that vintage. Just go look in the for UK forum and you'll see the terminology everywhere. S2000 GT was also a limited edition model in the UK produced to commemorate the end of S2000 production in 2009. Not trying to be disagreeable, just making a minor correction.
To the OP, was your S previously repaired?
Old Jan 27, 2014 | 03:53 PM
slalom44's Avatar
Top Answer: 1
Originally Posted by neuronbob
There is a GT model in the UK, and from that vintage......
Ahhhh.... Sorry, I didn't know that.
Old Jan 27, 2014 | 05:00 PM
fernando.'s Avatar
Pictures? I've never seen rust on an S2000.
Old Jan 28, 2014 | 02:47 AM
surfer_crx's Avatar
Both my rear arches were rusting, they tend to bubble. It was rusting from the inner, the only way to get rid is to cut it out as previously mentioned. I bought a rear half of a front damaged car and had the quarter panels removed and put on to one of mine and you wouldn't know they weren't original. You will need a good bodyshop but it was well worth it, when you have got the new ones on waxoyl the cavity.
Also rusting is a common issue in the UK.
brinb
Nov 8, 2016 12:31 PM
detailersdomain
Jun 23, 2014 01:53 AM
Dredd123
Aug 7, 2012 12:34 PM
Eze8199
Apr 27, 2002 12:52 PM
