S2000 Body and Paint Body kits, paint, ding repair and related discussions
To fix or replace front bumper
Old Aug 1, 2018 | 02:04 PM
oliversok's Avatar
Default To fix or replace front bumper
Hello everyone,
I wanted to see what you guys of my front bumper. It is in fair to bad shape and has been in an accident. I wanted to see if it would be more cost effective for a body shop to fix and paint it or just replace the front bumper with something else. Some pics for reference.
Old Aug 1, 2018 | 03:08 PM
rpg51's Avatar
I had a similar decision with my S. I had a minor strike with an object on the road that I could not avoid. The strike cracked the plastic front bumper cover near the bottom. The crack was similar in severity to your damage but in a different location. I made the decision to have my local high quality body shop replace the bumper with an oem part. It turned out great. But, I know will have to take a bit of a downward price adjustment if I sell. My feeling is that once the impact occurred I will need to disclose it to any buyer, so I might as well make the best possible repair, and my conclusion is that the best repair includes a new bumper cover. So, that is how I see it. What i am not really sure about, is whether that damage can be successfully repaired. Others?
Old Aug 1, 2018 | 03:24 PM
cosmomiller's Avatar
Top Answer: 1
Tough call. I think it depends on what the overall value of the car is to you and if you will ever sell it. Any other car with that damage I would replace and repaint the bumper. (High value car I would pay to have it done)
I am not sure how well a shop can repair and repaint that and keep the VIN intact. You might want to take pictures so you can show the eventual buyer it was not a major collision that cause the replacement.
Old Aug 1, 2018 | 03:55 PM
oliversok's Avatar
Yea it was a long shot. Im trying not to spend much money on this car as it is still fairly depreciated in value. Well I guess I might as well get a aftermarket bumper in the process of getting the car to be in better shape.
Old Aug 1, 2018 | 04:15 PM
ssbfgc's Avatar
Looks like the VIN is absent? If not, get a replacement and hold on to the old number.
Old Aug 1, 2018 | 04:20 PM
oliversok's Avatar
Thats smart. Didnt think of that. Thanks for the advice
Old Aug 1, 2018 | 04:50 PM
Hfreak's Avatar
As stated there is no VIN, no change in what you have if you replace it. Also, would be willing to bet that the cost of plastic welding and finishing would be more than a new RDOT bumper and for sure a descent used bumper. The paintwork is where the money is spent though, if you can find a good used version in your colour then jump on it. Good luck.
Old Aug 2, 2018 | 02:50 PM
Manga_Spawn's Avatar
Site Moderator
It depends on what you mean by "replace it with something else." Do you mean an aftermarket bumper or an OEM replacement? If OEM replacement then yeah buy the new bumper and have it paint matched. If aftermarket it all depends on what bumper you buy and how the fitment ends up being as you could spend a lot having a body shop make a poorly fitting bumper fit.
Old Aug 27, 2018 | 12:38 PM
Mr._ap1's Avatar
Dealing with the same issue with INS right now. They didn't want to acknowledge the internal damage, which is visible to the eye so I'm going to take it to get an inspection at a repair facility may be required to resolve any differences.
1 600008 BDY REMOVE/INSTALL Frt Bumper Cover INC
2 600010 BDY REPAIR Frt Bumper Cover Existing 2.5*
3 REF REFINISH Frt Bumper Cover C 2.0
4 601376 BDY REMOVE/INSTALL Frt Bumper Tow Hook Cover Existing 0.1 r
5 600025 BDY REMOVE/REPLACE R Frt Bumper Stay 71143-S2A-000ZZ 39.20 0.2 #
6 REF REFINISH R Frt Bumper Stay C 0.5
7 600027 BDY REMOVE/INSTALL Frt Lwr Bumper Grille Existing 0.2 r
8 600039 BDY REMOVE/INSTALL Frt Bumper Emblem Existing 0.2 r
Front Lamps
9 600044 BDY REMOVE/REPLACE R Frt Combination Lamp Assembly Remanufactured 536.00 1.9 #
10 BDY CHECK/ADJUST Headlamps 0.4
11 600072 BDY REMOVE/INSTALL R Side Repeater Lamp 0.2 #
Front Fender
12 600198 BDY REPAIR R Fender Panel Existing 2.0* #
13 REF REFINISH R Fender Outside C 2.0
14 600204 BDY REMOVE/INSTALL R Fender Liner Existing 0.4 r
15 600212 BDY REMOVE/REPLACE R Fender Adhesive Emblem 75710-S2A-000 19.70 0.2
16 S
17 600214 BDY REMOVE/REPLACE R Fender Adhesive Emblem 75711-S2A-000 33.42 0.2
18 2000
Additional Costs & Materials
19 936012 ADD'L COST Hazardous Waste Disposal 5.00
20 REF ADD'L OPR Clear Coat 1.3
21 ADD'L COST Paint/Materials 204.00 *
Special/Manual Entry
22 900500 REF * REFINISH/REPAIR CORROSION PROTECTION - MINOR REPAIR Sublet 10.00 * 0.2*
23 900500 BDY * ADD'L LABOR OP COVER CAR FOR OVERSPRAY Sublet 10.00 * 0.2*
I. Total Labor: 666.80
II. Total Replacement Parts: 666.02
III. Total Additional Costs: 221.54
Gross Total: 1,554.36
INS is to save as much $ as possible even if your car isn't safe to drive on the street anymore
caleb2483
Oct 1, 2009 04:40 AM
rtmpaul
Jul 17, 2006 02:05 PM
vtecker
Sep 22, 2005 03:26 PM
kctham
Feb 14, 2005 01:48 PM
HJZ
Nov 8, 2003 12:49 PM
