S2000 Body and Paint Body kits, paint, ding repair and related discussions
Got a new top, how to prevent rips?
Old Jan 19, 2011 | 02:40 PM
mse678's Avatar
Default Got a new top, how to prevent rips?
Hi all, i just got a brand new top for my s2k. i remember seeing a thread a while back that someone use some sort of wrap from a bicycle to wrap around the bar from the soft top to prevent it from ripping
anyone know what i m talking about?
Old Jan 29, 2011 | 11:13 AM
smohan123's Avatar
The gist of a DIY fix (perhaps the one you are referring to) for this is:
Patch tonneau wear point(s) with pieces of black gaffa tape, then sleeve the “elbow” of the frame that seems to cause the problems by adding velcro hooks down the edge of a piece of black bass box cloth (12 cm x 14 cm) and wrapping it around the elbow
I'd recommend griding down the rough weld on the right rear frame "elbow".
Old Jan 29, 2011 | 07:17 PM
croftoncustoms's Avatar
keep it clean and UV protected using Ragg top.
Old Feb 1, 2011 | 02:56 PM
Tackninja's Avatar
Do not stab the top with a knife.
Also, as the top break in, allow it to go down slowly, stopping to manually fold it in place.
Deburr the frame.
Old Feb 1, 2011 | 04:30 PM
wrecked's Avatar
When grinding the weld, Is it easiest top down? Is it only on the right rear?
Old Feb 1, 2011 | 04:34 PM
smohan123's Avatar
I have a little wear in the tonneau on the right side and significantly less on the left side.
As my top is up for the next few months I have not yet adjusted the weld. You may need to do some digging online to find out about that particular aspect of the "fix". The gaffa tape, box cloth, velcro DIY should forestall any wear on the top for quite some time, though.
Old Feb 10, 2011 | 04:54 PM
thefishstick's Avatar
Are you talking about wear?
I remember seeing in a DIY thread where they cut two squares of material off the old top and put them between the plastic guard and the new top with adhesive.
Here's the link:
https://www.s2ki.com/forums/index.php?showtopic=448840
Old Feb 10, 2011 | 07:14 PM
SlowTeg's Avatar
Here are a couple useful threads of mine I started a while back.. The first one has a lot of links regarding top tears and solutions. The second one is more specific to a tear that started developing for me above the driver's head.
I applied patches to the two wear points I had, and bought lizard chain stays for each side as shown in the threads.
https://www.s2ki.com/forums/index.php?showtopic=775556
https://www.s2ki.com/forums/index.php?showtopic=799899
dea7hr0w
Sep 29, 2012 06:14 AM
CHUCKLIDDELL101
Dec 24, 2010 02:13 PM
