Sewing holes on softtop
Old Sep 26, 2012 | 07:33 AM
dea7hr0w's Avatar
Default Sewing holes on softtop
Has anyone sewed the softtop to close up a small rip on your soft top before?
I also have a square patch that I am thinking of sewing to close the rip.
Any suggestions?
Old Sep 26, 2012 | 08:56 AM
Ken1997tl's Avatar
Sewing is easy. You should instead be addressing why a hole is forming. In my case, it was a burr on the metal hoop that was rubbing up against the top. I sanded that down, no more abrasion.
Old Sep 26, 2012 | 09:59 AM
lopez14's Avatar
Very easy, just get a needle with string and in & out you go
Old Sep 26, 2012 | 12:19 PM
mazelmazelgoodthings's Avatar
sew it up!
Old Sep 26, 2012 | 01:05 PM
Miasma's Avatar
I've also wondered about just sewing it up. I've got a small hole that's been patched but the adhesive seems to be giving up. Would it make sense to use a new patch + adhesive and then sew it as well or would I be fine just sewing the patch that's peeling back on?
No thread jack intended, just curious.
Old Sep 26, 2012 | 01:20 PM
Si Isnt Enough's Avatar
I contemplated sewing mine after my whole kept getting bigger and bigger, even with my previous patch method. I finally deburred the frame (it was only ripping on the passenger side) and used the black ice patch. Works beautifully and is showing no signs of wear!
Old Sep 26, 2012 | 04:04 PM
kap's Avatar
kap
Also, when you sew it, try to sew in the direction of the vinyl grain as it will hide itself better.
If you sew against the grain, it is much more noticeable.
So, sew it along the grooves the the grain (not too much), when use whatever your favorite patch method is the cover up the underside.
Old Sep 28, 2012 | 02:36 AM
flacoloco's Avatar
try this...
http://www.zjstech.net/SpyderTop/repair.htm
Old Sep 28, 2012 | 08:33 AM
S~Factor's Avatar
^tried that. That thing is a pain to use and if you don't have a lot of patience, you will more than likely will make it worse.
I tried stitching mine and it just made it worse because now you have a dozen of tiny holes that will stretch and become big holes later on.
Just glue a patch and take it for what it is, a temporary fix, until you get a new top.
Old Sep 29, 2012 | 06:14 AM
RandomAP1's Avatar
I had small tears starting in my top and I sewed mine then put a patch on the inside.
The patches and adhesive is still holding strong and tears havent gotten any worse.
I did a DIY write up on it but its mostly common sense...
https://www.s2ki.com/s2000/topic/943...#entry21607210
RL1924
32
Jun 10, 2013 06:05 AM
CKen
Aug 2, 2012 06:51 PM
JmanS2k
Mar 22, 2011 05:30 AM
TheRook
Mar 9, 2010 05:07 PM
financedirect
Jan 7, 2010 09:34 AM
