S2000 Body and Paint Body kits, paint, ding repair and related discussions
Molding the CR lip to the bumper
Old 02-24-2012, 07:39 PM
S~Factor's Avatar
Default Molding the CR lip to the bumper
Is it possible for a CR lip to be molded to the bumper and not crack under normal use? What kind of "bondo" is used?
Old 02-28-2012, 05:58 PM
sata3000's Avatar
prob would need fiber glass. I bet the first pot hole you hit it starts to crack.
Sent from my Galaxy II using Tapatalk
Old 03-01-2012, 06:29 AM
Former Sponsor
JBAutosports's Avatar
If you live somewhere where there are drastic temperature changes, you will have cracking over time with molded lips. I have seen this on molded bodykits where work was performed by excellent bodyshops. Its just nature. Plus, you would have to drive more carefully - why do you want to mold it? Just curious...
Old 03-01-2012, 02:18 PM
S~Factor's Avatar
I have a tiny gap between the bumper and the CR lip that the rubber moulding can't cover.
I am looking more of a plastic heavy duty glue than 'bondo' type paste. I need it to be strong, making the 2 bond as one.
Old 03-01-2012, 05:32 PM
sata3000's Avatar
Ah ok.. Do you have a Car quest around you? If so get a 2 part glue. glue/ activator . for best adhesion scuff the paint with a red 3m scuff pad so the glue can bite into the paint.
Old 03-02-2012, 06:18 PM
irmos2k's Avatar
Auto body shops have something that we use for plastic repair, for repairing cracks, can't remember off the top of my head what it's called, but it bonds two pieces of plastic stronger than the original piece is, it's stronger than bondo and fiberglass, but takes awhile to sand down to make flush, I'm sure after that you can add some metal glaze over top of it to smooth it out and finesse it a little more. If I can remember what it's called I will let you know. I used this stuff on a bike(zx6r) on several different pieces of the plastic fairings and front fairing works wonders! Ask your body shop if they know what I'm talking about if not, i will try to find the name for it
Old 03-03-2012, 04:04 AM
S~Factor's Avatar
This it?
http://www.ebay.com/itm/3M-8243-Plas...18f40a&vxp=mtr
or this?
http://www.ebay.com/itm/3M-08115-Pan...49398250861252
Old 05-30-2016, 05:18 AM
vasquezgno's Avatar
Did you ever figure out why there was that small gap between cr lip and bumper? I've had this and never could fix it. I was about to just buy a new lip and bumper since its bugging me. Was thinking of double side tape on top of all screws. It's mostly on one side. The lays pretty flush
Old 05-30-2016, 12:40 PM
Vanishing Point's Avatar
There is a small thin rubber gasket that fits between the bumper cover and the spoiler, it's a OEM part which I believe is 71108-S2A-010.
Old 05-31-2016, 08:54 AM
Amplified_AP1's Avatar
There is a product call Fusor, similar to the 3m product you posted, it allows you to plastic weld, and evercoat sells filler you can use, should do the trick. The VW crowd have been doing it to shave their markers forever. also example
Quick Reply: Molding the CR lip to the bumper
