S2000 Body and Paint Body kits, paint, ding repair and related discussions
PDR Rear Quarter panel
Old Dec 3, 2017 | 05:16 PM
Cade's Avatar
Default PDR Rear Quarter panel
Hello, I was hoping someone could answer this question from experience. I have a small ding along the car line and was told told by a PDR specialist the dent can be pulled but the best route is to drill a small hole where the door closes to access a place of leverage. Does anyone know if this area can be be accessed without tapping a hole? I tried taking off some of the paneling but still doesnt look like there is a clear line to access this area. Anyone have any input? The picture below is just a reference of where the ding is located. Thanks
Old Dec 3, 2017 | 07:51 PM
afzan's Avatar
no it cannot
Old Dec 4, 2017 | 10:15 AM
Cade's Avatar
Originally Posted by afzan
no it cannot
thanks for the reply. Were you in a similar scenario? If so what did you end up doing?
Old Dec 4, 2017 | 12:48 PM
lookstoomuch's Avatar
My father in law does pdr for a living and he cleaned up some dings on mine in a similar area. A plastic plug now fills the hole he drilled to access them. Now it's there for the next time a ding needs to be cleaned up.
I believe an alternate method to using the rods is glue pulling but I don't know how / Why / when this method is used vs. rods.
Old Dec 6, 2017 | 08:11 AM
Cade's Avatar
Alright thanks, looks like I will need to do that. Appreciate the info
Old Dec 6, 2017 | 09:56 AM
Midnightdennis's Avatar
I've seen similar dings on the same body line but closer to the tail light. PDR specialists would take the tail light out for better access and use a long pole/stick to help get the ding out. Maybe that's an option here?
Either way, I've had a hole drilled/tapped in the door jamb before and did not have a negative experience with that. GL OP.
CrapMaster
Dec 2, 2013 08:46 PM
lltysonll
Mar 2, 2013 05:09 PM
M00C0W25
Jan 20, 2005 08:19 PM
heggem
Jun 16, 2004 12:16 AM
DeluxeS2k
Jan 24, 2004 11:12 AM
