Rear fender liner - Does the S2000 have them
Hi All,
As I am trying to discover my S2000 (2005 AP2) bit by bit, I feel that I am missing the rear fender liners, there is a massive gap when I look at the car from the top of the rear tires looking backward. Something tells me there is something wrong here. The PO also has cut a 3/4" slot right above the rear license plate which I thought was effing weird, could the two issues be related? Appreciate your help with this, if I am missing the rear fenders, I want to order them from the dealer before they are all gone!
Thank you.
Thank you.
As noted your '05 is normal and correct. A couple of years ago someone was selling aftermarket rear fender liners here. A search may turn up the information. Honda did not fit them for a reason I'm sure, they're inexpensive enough to have been factory fitted if they had any benefit. Theories regarding them causing more turbulence and trapping more air under the car affecting handling have been proposed.
-- Chuck
-- Chuck
I was scared that the owner was messing about with some aero modifications, glad to hear that its all normal, whew !!!!!
Really amazing forum and I truly appreciate your assistance and your patience.
There are a lot of threads/stickies that discuss a lot of common questions. I'd recommend reading through them.
https://www.s2ki.com/forums/s2000-ta...l-info-753204/
https://www.s2ki.com/forums/s2000-ta...-s2000-775801/
Also, the search function works too for answering most questions.
